Trickflow Head Q's????
In your sig it says "supercharger for sale", if you read the Trickflow description it says those are for boost or strokers, even they are telling not to use them on an NA stock shortblock.
Given the roughly 64cc iron head motors 10:1 with a .029 gasket I think with a .039 gasket you will be pretty damn close to that number.
Also, last time I checked, deck height was .015" for a stock bottom end LT1 w/ aluminum heads.
Also, I thought (could be wrong) the 4.5cc of piston was calculated into the CC volume that totaled 58cc. If not then just take out 4.5 from that and re do math. CR will go up.
When I had the heads off my motor we got a little shadetree and used a small straightedge and feeler gauges and came up with about .022, I have seen guys talk about over .030 on this site as well.
