Pacesetter LT's??
Old Jun 22, 2006 | 07:43 PM
Camaro94SS's Avatar
Default Pacesetter LT's??
When installing headers on an LT1, pacesetters to specific, would i have to lift engine out? How would it work?
Old Jun 22, 2006 | 07:47 PM
CW00BlackTA's Avatar
Can't speak from experience for an LT1 (someone will chime in soon). The trick is to go at it from the bottom. You don't have to with an LS1 and I wouldn't expect it to be different for yours.
Old Jun 22, 2006 | 08:10 PM
Camaro94SS's Avatar
Anyone with an LT1 give me some info??
Old Jun 22, 2006 | 11:11 PM
slo95z's Avatar
on my 95 the driver's side went in from the top after unhooking the steering shaft and on the passenger side I put it in thru the bottom, had to remove the starter and dipstick. I also installed them the same on a 94. You will need to get the front up about a foot and a half tho.
Old Jun 23, 2006 | 01:00 AM
JUICED96Z
Guest
Posts: n/a
Agreed, heard it helps a lot if you have an engine hoist. Just pull the engine up some and it gives you a bit more clearance.
Old Jun 23, 2006 | 01:53 AM
94z28L's Avatar
didnt have to lift the motor just do what these guys said with pulling accessories and having it up a good amount
Old Jun 23, 2006 | 08:12 AM
JL8Jeff's Avatar
I had to lift the motor on the passenger side to get that header in on my 96 SS. But I have emission's headers which made it a lot tougher. Each install is a little different, but you might as well be prepared for a worst case scenario.
Old Jun 23, 2006 | 08:56 AM
the_merv's Avatar
Veteran: Air Force
I know that you have the remove the Steering Shaft. I am changing the Head Gaskets, so I am installing the LT's then. I am taking the Heads off, sliding the LT's in, and then puting the Heads on and bolting the Headers to them. That should be a little easier than what most people do.
Old Jun 23, 2006 | 05:31 PM
Ralls's Avatar
I also have a 94' and I couldn't get the header in on the passenger side. It kept hitting the K-member. I never got that side in so I didn't bother with the driver side. I was running out of time and didn't have the right tools available. So a shop did it for me. Thats all I know about it.
Old Jun 23, 2006 | 07:10 PM
urbanhunter44's Avatar
on my 97 i undid the steering shaft on the driver's side and it slid right in. On the passenger's side I took the bolt out of the motor mount, and jacked the motor up on that side about an inch for extra clearance. Remove the starter as well.
Old Jun 23, 2006 | 08:58 PM
slowmofo's Avatar
I lowered my K-member to get the Pass side in, didn't have to remove the starter, but you will have to remove the dipstick. Drivers side was easy.
Old Jun 23, 2006 | 09:20 PM
94Z396's Avatar
I recommend a better set of headers. I have pacesetters on my 94 and there going on my 396 stroker and the way there made really isnt that good. They hit the floor board on both sides and don't really flow that good. A good set of Kooks or Hooker Super Comp's would be way better. Thats just my 2 cents worth though.
