Lt4 intake?
Old Jul 3, 2006 | 12:04 AM
94 z28 A4's Avatar
Default Lt4 intake?
I am wanting to get an Lt4 intake but i was
wanting to know if i get it will it work with all
the lt1 stuff and motor or will i have to buy
more than just the intake to make it work?
Will i have to get a tune after i get it put on?
Thanks
Old Jul 3, 2006 | 12:20 AM
udlose99ta's Avatar
you will have to do a little grinding on the edges of the intake to make it fit with lt1 heads, other than that no other parts are needed. You wouldnt need a tune if thats all your doing.
Old Jul 3, 2006 | 12:29 AM
94z28L's Avatar
just wondering why you want to do only the lt4 intake?
Old Jul 3, 2006 | 12:30 AM
TwoFast4Lv's Avatar
why are you wanting a LT4 intake? No performance advantage over a LT1 intake at all and the prices are through the roof for them now.
I would just port a LT1 intake
Old Jul 3, 2006 | 07:41 AM
GIZMO's Avatar
If you want an LT1 manifold with the same port configuration as an LT4 manifold find one from a 1997 LT1. The ports on this intake mirror the ports on the heads unlike the square ports on the earlier manifolds. I tried one on one of my Stock Eliminator motors, but saw no gains with it.
Daren
Old Jul 3, 2006 | 08:01 AM
96capricemgr's Avatar
As was said you could do some grinding on the outside of the manifold to make it fit LT1 heads BUT in doing so you take away every potential advantage an LT4 intake has. As was also mentioned the LT4 intake is internally the same as some of the LT1 intakes so swapping too it would be ruining a piece someone else might have been actually able to make use of and a complete waste of money for you.
They had extra material on top of the ports to seal to the taller ports on the LT4 heads, this also facilitates port matching to taller port heads, you take that material off to make it clear the valvecover rail on LT1 heads and you effectively made yourself a red LT1 intake that cost a whole crapload of money.
Old Jul 3, 2006 | 08:13 AM
the_merv's Avatar
Yea, unless you have LT4 Heads, or Heads with taller ports, you don't need it, so don't waste the money.
Old Jul 3, 2006 | 11:37 PM
94 z28 A4's Avatar
How much will it be to get mine ported?
Old Jul 3, 2006 | 11:51 PM
oneBADDz's Avatar
AND, they don't make em anymore, so you have to find someone that's willing to part with theirs
Old Jul 4, 2006 | 12:27 AM
Honda Hunter's Avatar
I have one for sell but I wouldnt even sell it to someone unless they needed it to fit thier LT4 heads or AFR setup.
Old Jul 4, 2006 | 06:20 PM
I would only get the intake ported if having the heads done and then let the heads guy do it, talk to him about price.
