Car wont roll over??? HELP!!!!!!!!!
did you check the 12v at the purple wire on the starter while trying to start the car???
Take you Volt Meter and have it set on OHMS. Take each test lead and place it on each of the white wires going to the keyswitch. Put your key in the ignition. Take a ohms reading, then turn the key to ON and then to START...take another reading. If NOTHING is showing(or changes between no key and with the key installed) on the meter with the key in off,on, and start. Then more than likely the small VATS wires in the keylock cylinder broke. They rub the lock cylinder when cycling the key and will break.
If you don't want to do that(TESTING), then pop the lock cylinder out and see if the white wires are broke.
thanks for the info JPATI, im gonna go and check that right now
also, ive noticed that when i turn my key to the on position, the lighting for my dual guage pod doesnt come on, the guages will work, but the lighting will not. They should come on when the key is on.
