opinons on lt1 383
Old Jul 8, 2006 | 12:12 PM
spike30th's Avatar
Default opinons on lt1 383
I been debating on this motor on ebay. I was told this motor can handle 550hp. It seems like a good deal for $2100. What do you guys think of of it?
http://cgi.ebay.com/ebaymotors/BALAN...spagenameZWD1V
Old Jul 8, 2006 | 12:36 PM
White 96LT1's Avatar
there is a guy on this site selling his for $1800 with the heads
Old Jul 8, 2006 | 12:45 PM
NOSARMD's Avatar
The componants are less then impressive. I am willing to bet that the crankshaft, although Eagle, is probabley cast not forged. I guess it really depends on what your plans are for your car.
SPEED PRO Hypereutectic Pistons
Hastings Moly Rings
Clevite 77 Rod Bearings
Clevite 77 Main Bearings
Melling High Volume Oil Pump
Fel-Pro Lower Gasket Set
Durabond Cam Bearings
Pioneer Brass Expansion Plugs
Eagle 3.750" Crankshaft
Reconditioned LT1 Connecting Rods
Old Jul 8, 2006 | 01:08 PM
9formula4's Avatar
Why not have your old block machined and order a stroker kit with the forged parts instead of using "reconditioned" parts. thats just short for "I was broke and couldn't afford to get new rods".
Old Jul 8, 2006 | 02:04 PM
97blkz's Avatar
Hastings Moly Rings
Ehh i was thinking along the same lines, my crank cost $1100.
Old Jul 8, 2006 | 02:10 PM
streetwarrior96's Avatar
I would'nt go with that. I'm not a fan of "reconditioned" parts. The pistons arent all that.
I bought my engine from this guy. Works great
http://cgi.ebay.com/ebaymotors/SBC-L...5342QQtcZphoto
Old Jul 8, 2006 | 09:07 PM
aggiez28's Avatar
i dunno what your looking for but i wouldnt get that, at least put decent pistons and rods in it
brook
Old Jul 8, 2006 | 09:11 PM
burnzilla's Avatar
Not a deal.
Here you go...http://www.dyno-flo.com/index.php?pr=rotassemblies
Youre welcome.
________
Any on a side note, buying several 383 parts does not mean you have a 383 CI motor.
YOu can buy 383 blocks, and they aren't cheap.
Old Jul 9, 2006 | 08:34 AM
LS1DUCE's Avatar
Default 385 Lt1
I have a motor for sale
Lt1 385 Stroker.Wiseco .040 flat top nitrous pistons.Scat forged crank.H beam rods,oil pump,6qt oil pan,comp nitrous solid cam 601/609 248/256,solid lifters,comp 1.5 roller rockers.cloyes true roller chain.
Ported lt1 heads 2.02 1.6 w/roller springs,guide plates Head studs, Main studs.etc.....
Just needs to be assmbled
Pics on request
I live in upstate NY
$3200
Old Jul 9, 2006 | 12:17 PM
spike30th's Avatar
Pics on request
$3200
could you please send some pics
Old Jul 9, 2006 | 12:37 PM
LS1DUCE's Avatar
Default LT1 Pics
i sent u a pm
Old Jul 9, 2006 | 01:06 PM
z28hustle's Avatar
Originally Posted by burnzilla
Not a deal.
Youre welcome.
________
Nice link
I would recommend the guy who started the thread to find out what parts people have who are running the way you want to run. Then find out what are the best out parts (mixed and matches probably) from those motors/people and build the best one you can afford.
Old Jul 9, 2006 | 03:05 PM
spike30th's Avatar
Not a deal.
Youre welcome.
________
this was the other motor I was checking out on ebay. It has better pistons,rods and crank and its from dyno-flo.
http://cgi.ebay.com/ebaymotors/LT1-3...8758QQtcZphoto
Old Jul 9, 2006 | 03:54 PM
NOSARMD's Avatar
It is a better set up then the previous one.
CHEVROLET LT1 BLOCK/ reconditioned
JE/SRP Forged Pistons Flat Top +.030 1.125 C.H. 10.8:1 with 64cc head
EAGLE SIR 5140 FORGED STEEL RODS6.0 Full Floating Pin
Eagle CAST STEEL/ NODULAR IRON 3.75" CRANK 1 PC REAR MAIN SEAL
KING BEARINGS AND MOLY RINGS FILE FIT
Old Jul 10, 2006 | 08:38 PM
UA-Plumber's Avatar
Check out Golens 383's they seem reasonable. Plus there was a writeup about them in GMHTP. Ive heard nothing but good things about them.
Old Jul 11, 2006 | 07:24 AM
NOSARMD's Avatar
Copied this from a thread on camaroz28.com. There is a huge difference in part quality in there to the previous ones you listed, but not that much of a price jump.
355LT1 Economy Shortblock-$2999.99 NO Core Charge
-Eagle 3.480” stroke Cast Crankshaft, Eagle H-Beam Connecting Rods, SRP Pistons, Perfect Circle Rings, Clevite Main Bearings, Clevite Rod Bearings , Clevite Cam Bearings, ARP Main Studs.
355LT1 Racer Shortblock-$3290.00 NO Core Charge
-Eagle 3.480” stroke 4340 Crankshaft, Eagle H-Beam Connecting Rods, SRP Pistons, Perfect Circle Rings, Clevite Main Bearings, Clevite Rod Bearings, Clevite Cam Bearings, ARP Main Studs.
383LT1 Economy Shortblock-$3199.99 NO Core Charge
-Eagle 3.750” Cast Crankshaft, Eagle H- Beam Connecting Rods, SRP Pistons Perfect Circle Rings, Clevite Main Bearings, Clevite Rod Bearings, Clevite Cam Bearings, ARP Main Studs.
383LT1 Racer Shortblock-$3415.00 NO Core Charge
-Eagle 3.750” stroke 4340 Crankshaft, Eagle H-Beam Connecting Rods, SRP Pistons, Perfect Circle Rings , Clevite Main Bearings, Clevite Rod Bearings , Clevite Cam Bearings, ARP Main Studs.
396LT1 Racer Shortblock-$3490.00 NO Core Charge
-Eagle 3.875” stroke 4340 Crankshaft, Eagle H-Beam Connecting Rods, SRP Pistons, Perfect Circle Rings, Clevite Main Bearings, Clevite Rod Bearings , Clevite Cam Bearings, ARP Main Studs.
Old Jul 16, 2006 | 08:23 AM
94EvilZ28's Avatar
I went with Golens...and I was very happy...I had to swap out some parts being that mine was a 94...but you wont have that problem...I went with a somewhat custom 383...
