short block vs. long block
Old Jul 14, 2006 | 01:07 PM
ToxicFormula's Avatar
Default short block vs. long block
I've been looking around at different LT1 block cause I plan on building a very "healthy" motor in the near future and I was wondering. What are the differences between a short block and a long block? Is it simple that the long block is actually longer then the short block?
Old Jul 14, 2006 | 01:10 PM
streetrod93's Avatar
the short block refers to everything below the heads....just a block and rotating assembly
long block refers to an entire motor....or at least up to the heads...
if you're looking to build a "healthy" motor, i'd find a good short block somewhere and buy a set of good heads (AFR, TFS, or call someone like lloyd elliot and have him port and polish a stock set)
mike1500's Avatar
IM guessing bigger bores?
Old Jul 14, 2006 | 01:11 PM
wrd1972's Avatar
I hope I am saying this right.
A short block is the block only with crank, pistons bearing and caps assembled only.
A long block is all of the above plus cam, heads and valvetrain plus timing set.
Old Jul 14, 2006 | 01:12 PM
Hot94Z28's Avatar
Short block means just your bottem end long block means everything but your bolt ons like intake and accesseys
Old Jul 14, 2006 | 01:16 PM
OoOoOoOoOoooooooo ok. Thanks a bunch for clearing that up for me. lol why dont they just call them short blocks and tall blocks? cause when I think "long" I think length not height.
Old Jul 14, 2006 | 01:17 PM
some people do...just a preference of syntax
