arcing problem
Old Jul 20, 2006 | 02:28 AM
blue94's Avatar
Default arcing problem
ok, I've been having this ongoing arcing issue for several months now. The opti was new from ac delco less than 6 months ago along with new delco wires, and new delco plugs. The car ran GREAT after that, than one day it started arcing and kind of developed a miss. Well we changed the plug out that was arcing and than another one was arcing. So we swapped all the plugs out for NGK's and I'm still having the problem. You can see arcing off of the coil wire and also off the plugs/spark plug boots. the car is just running like crap and now I have been getting the SES light over the last couple days, but I haven't gotten it in to get scanned yet. You think the plug wires are bad? coil? the coil is the only originial ignition part left. The problem seems to get worse with engine heat and it also worse the hotter it is outside.
Old Jul 20, 2006 | 02:37 AM
blind527's Avatar
The plug wires are bad.
Old Jul 20, 2006 | 09:15 AM
lt197formula's Avatar
Exactly what ^ he said I had the same problem before, changed the wires and all was good.
Old Jul 20, 2006 | 07:34 PM
blue94's Avatar
damn...that sucks, these wires are less than 6 months old
Old Jul 20, 2006 | 07:59 PM
HBHRacing's Avatar
arc is caused by high resistance. Good contact is essential. The high resistance can be anywhere that there is a mechanical gap in the spark path. Make sure all of your connection are clean and tight, and use dielectric compound to aid in contact.
Another reason for arc is due to high resistance in the combustion chambers, due to a lean running motor. You might want to look into that as well.
Old Jul 20, 2006 | 08:05 PM
blue94's Avatar
what would possibly be causing it to run lean? It is pretty much stock except for a K&N CAI and gutted cat
Old Jul 20, 2006 | 08:08 PM
HBHRacing's Avatar
Any of your normal lean issue. Too much heat, too little fuel, unmetered air entering the motor, etc etc
Old Jul 20, 2006 | 08:36 PM
b00ya4u2's Avatar
i have a problem with my opti arcing on my water pump. its beginning to **** me off.
Old Jul 20, 2006 | 09:51 PM
94EvilZ28's Avatar
^^ Again...I think that would be your wires too...unless your casing is cracked...but i cant imagine seeing that...
Old Jul 20, 2006 | 10:48 PM
b00ya4u2's Avatar
its not the wires, i thought it was the coil wire n changed it. still does it. i can see it from under the car, its opti to waterpump no wires near it
Old Jul 27, 2006 | 02:38 AM
blue94's Avatar
so have any of you personally had a similar problem and fixed it by changing wires? and if so what kind of wires did you use and what would you suggest?
