Headlight upgrade.......
Old Jul 20, 2006 | 11:18 PM
transam5.7lt1's Avatar
Default Headlight upgrade.......
Well... seems like it might be a problem... but I am kind of confused.....
Went and bought a set of Sylvania Silverstar headlights for my 1994 Trans Am.... I installed them but they look just like the stockies, I went back and returned them, came back with a set of cool blue headlights.... same thing, those looked again like the stockies.... so... can anybody give me a hint of whats wrong??? Doesn't seem like a ground problem, since stock ones work great... I was just looking to get a light that would look a little more updated... anyone had a situation similar like mine? I am now running the stock headlights...... Part number shown on catalog is: H4666
Old Jul 20, 2006 | 11:30 PM
Gun5's Avatar
HID will give u a different look.. other then that all those stupid XENON bulbs are just bright white (great for driving ya but not that coolass effect) im gonna go HID as soon as money permits
Old Jul 20, 2006 | 11:41 PM
I see your point..... but, shouldn't I see a difference in brightness on Silverstar and Cool Blue from stockies????? All I am saying is that both looked like stock lights, no blueish-white light effect!! I can call BS on the claims for "brighter", "close to HID" on both........
Old Jul 20, 2006 | 11:45 PM
Gun5's Avatar
hmm i went euro lights online... bright whtie like 6000k it was whiter then stock on my 04 elantra
Old Jul 20, 2006 | 11:46 PM
harvickgm's Avatar
hold on got one for ya... there was a post here about this not that long ago....
https://ls1tech.com/forums/showthrea...ght=headlights
then go to this site and look at the 165mm conversion and they are cheap too....
http://www.rallylights.com/hella/165mm_lo.asp
Old Jul 21, 2006 | 12:58 AM
buffman's Avatar
because the sylvania cool blue and silverstar headlights have the exact same lumen output as your stock bulbs. they show a brighter color (kelvin) white, but are basically no better than stock. an 80 and 100 watt bulb would be an improvement, but not sure how well your F-body headlight wiring harness is. I know the B-cars cant even handle the stock bulbs let alone aftermarket ones.
Also sticking an HID bulb more specifically an HID conversion bulb (since ones that fit halogen lamps are just rebased bulbs) in a halogen lamp is a bad idea IMO. you're throwing a light source in a housing not meant for it. You're going to end up throwing light all over the road, especially into oncoming traffic. But what do I KNow :0
Old Jul 21, 2006 | 06:49 PM
I see your point buffman, but I am not talking about light output... I tried both, silverstar and cool blue... none had a bluish effect, none had a whiter effect.....
Old Jul 21, 2006 | 07:41 PM
harvickgm's Avatar
did you go to the links i gave you... they are direct replacements with the adapter for the H4 and you can pick the wattage you want...
Old Jul 21, 2006 | 08:53 PM
seawolf06's Avatar
Did you use silverstars or just the regular sylvanias? I switched to the silverstars and they're much much brighter now.
Old Jul 21, 2006 | 09:02 PM
DeltaT's Avatar
A true HID conversion will run you at least $1400, becuase they need a special power supply.
I would run 90/130 H4 bulbs but to do that you need to use a relay with power drawn directly from the battery - your stock wiring will not handle that amount of current.
Are you trying to see better or look cooler? Very different goals. Some of the 'coolest' looks turn out to be obnoxious to other drivers and attract the cops.
Jim
Old Jul 21, 2006 | 09:10 PM
96capricemgr's Avatar
In the b-bodies wiring upgrades are GREAT can't imagine the f-body got much better wiring. Worry about getting the most from your current bulbs before you worry about replacing them. Trying to put brighter bulbs in without wiring is like camming without intake and exhaust.
