Small part, big problem. Knock Sensor plug is missing. Help.
Old Jul 21, 2006 | 08:39 PM
LS1 Eddie's Avatar
Unhappy Small part, big problem. Knock Sensor plug is missing. Help.
Heres what happened. When I pulled my motor, we forgot to take the knock sensor out and the plastic tip snaped off. No big deal, I just went to the dealership and got a new one. Now that the motor is basically fully assembled in the car, as we are hooking up all the sensors I cannot find the plug for the knock sensor. I've spent hours under the car and on the top trying to find it and it's nowhere. Could someone give me some tips as to how I could go about fixing this? Where does the knock sensor wiring come from? I have thousands of dollars into this build up and I'm at a stale mate over a stupid knock sensor plug. Any help or suggestions are welcome, please help me.
Old Jul 21, 2006 | 08:56 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Maybe this'll help?
http://shbox.com/1/ks.jpg
Old Jul 21, 2006 | 09:09 PM
DeltaT's Avatar
Good pic - there's hole in each side of the block that will accept the knock sensor or a 3/8" NPT plug. Usually the sensor is on the passenger side middle lower side of the block, like the pic.
Jim
Old Jul 22, 2006 | 07:19 PM
LS1 Eddie's Avatar
Jim,
What exactly is an NPT plug and where can I get one?
Thanks
Eddie
Old Jul 22, 2006 | 08:53 PM
TwoFast4Lv's Avatar
Notional Pipe Thread
any hardware store or auto store
Old Jul 23, 2006 | 02:13 AM
DeltaT's Avatar
I know you mean National Pipe Thread. Like TwoFast4Lv said, get NPT plugs in brass, steel, or cast iron at any Home Depot or OSH. Cheap to put together an assortment. Or get the fancier anodized aluminum ones at any speed shop. More expensive but slick in red, blue, black or silver.
The NPT standard is nice because if any part is the same diameter hole, the threads should match up. Get a tube of teflon thread sealer too. A modest amount on the plug or sensor thread, unless the sensor comes pre-coated.
Jim
