Optispark problems inside!!!
Old Jul 22, 2006 | 07:07 AM
EPP's Avatar
EPP
Question Optispark problems inside!!!
We have a customer's '94 Corvette that we built a 383 stroker LT1 engine for, and added an ATI ProCharger D-1SC. We have tried GM Optispark distributors with no success, and we now have an Accel distributor with the MSD cap and rotor. We keep having a reoccuring problem, the screws that hold the cap down back out all the way... We have even tried Loctite on the screws. Has anyone ever had this problem, and what did you do to correct it? The car does have a camshaft that lopes at idle, but of course it still shouldn't be doing this. Thanks for any suggestions. Bob
Old Jul 22, 2006 | 08:23 AM
HBHRacing's Avatar
Thats new to me. I have never had a problem with it before. Only things I can think of would be a balance issue or perhaps cam dowel too long. Neither would appear very likely to be the cause to me.
I will say that generaly, loctite will tend to crack plastic. There is proabbly something better to use for such applications.
Old Jul 22, 2006 | 10:38 AM
TwoFast4Lv's Avatar
I recently installed a DynaSpark for a customer and they claim not using a harmonic balancer(like many Impy's do) will cause this. I would think if this was true using a balancer that does not kill harmonics in the Right freq. might do the same thing.
One of the reasons I try to use Fluidampr's is they kill the most in the range a LT1 will run with a stock computer. Even ATI's Sight shows they do not even come close until 6,900.
Just a thought. I know you have been chasing this for a while and This one went on a 396 94 Vette also
BTW I had one other guy have his taken out over and over because one of his vacuum valves had failed. Just some thing else to check!
Good luck man!
Old Jul 22, 2006 | 11:34 AM
LetItRip's Avatar
I have a 94 z28, and all i can say is get that POS optispark out of there. I went with the msd pro billit distributor. It cost 500$ but its supposed to be bulletproof. It made the car drive alot smoother and i can take it up to 7000rpm all day without a worry. Well worth the money. good luck
Old Jul 22, 2006 | 11:45 AM
Twizted's Avatar
I Agree 100% best 500$ spent
Old Jul 22, 2006 | 02:09 PM
EPP's Avatar
EPP
Thumbs up
Good luck man!
Thanks, we'll check it out. Bob
Old Jul 22, 2006 | 05:53 PM
jb007's Avatar
LetItRip: Where did you get your distributor?
Old Jul 22, 2006 | 08:49 PM
LetItRip's Avatar
nytrus1 ordered it straight from summit for me. BUY IT
Old Jul 23, 2006 | 05:41 PM
redhot lt-1's Avatar
sounds as if the screws a a micro size to small because of the cross of the two procducts so i say go to the msd unit it will be money well spent
