whats wrong with my Formula?
I just put in a high torque starter & red top battery
it starts great but after driving today and i stoped it went shopping came back it did not do anything , nothing, but after it sat for about an hour it started?
whats up with her?
whats up with her?
Mines did that EXACT same thing, I went nuts trying to find the problem, battery, battery cables and finaly took it to HPE and had Big Rick and GoldRust take a look, turned out my mini starter (CVR) I had was junking out, was a year old. New stock style starter and the problem was solved. Your best bet and I knwow you dont wnat to hear this but is to borrow a stock LT1 starter and see if it goes away. What my car would do is, after you drove it, turn the key and nothing, but you could see the battery gauge drop. My problem was the mini starter, they sound cool though
Problem is if you pull the starter and have it tested it will come back fine since its cool. If the battery or battery cable is bad, when you turn the key, you should prety much loose power to every thing. Any Parts store starter carries a life time warranty, only way to go. Does the engine crank, but not start, or does the engine not crank?
this new starter worked great and after driving for awhile and it was hot outside 100*
I went to the store for about 30min then came outside I went to start my car and nothing, no click, nothing the gauge went down when you turned the key. the lights were bright and everything else worked, after about 15min later I tryed and it started right up. I also have a heat shield on this starter "power master high torque"
Oh when I rebuilt my motor I also put in a new accel coil
I'm going to hook up that wire this weekend
I was also thinking that if it acts up and won't start i'll use that wire to by pass my switch and start it like that.
I hate to think its my new power master high torque starter plus I even put a heat shield on it.
thanks for your help.
