Turn Signal question
Old Jul 26, 2006 | 07:21 AM
frey_TA's Avatar
Default Turn Signal question
I have a 96 Formula and I have been having problems with my driver's side turn signal and I can't figure it out. I have checked all the bulbs and fuses and everything checks out fine. I am guessing a bad ground but I dont know where to start. I need some help guys.
Old Jul 26, 2006 | 07:24 AM
HBHRacing's Avatar
do you have DRL's?
Old Jul 26, 2006 | 07:41 AM
frey_TA's Avatar
What are DRL's?
Old Jul 26, 2006 | 08:23 AM
HBHRacing's Avatar
Daytime running lights.
Old Jul 26, 2006 | 09:07 AM
frey_TA's Avatar
No it doesn't.
Old Jul 26, 2006 | 09:12 AM
HBHRacing's Avatar
Then just get to the socket with a test light or multimeter. Probe the wires before the socket and see if your getting constant ground and the hot "pulse". if one is missing, follow that to find teh cause. If both are present, replace the socket.
Old Jul 26, 2006 | 10:00 AM
frey_TA's Avatar
Thanks. I will try that.
Old Jul 26, 2006 | 10:07 AM
nodnarb481's Avatar
i also have a problem. The passenger rear turn signal will work but as im coming to a stop it will stop working. Its like it works when im driving but when i get close to stop it stops working
