oil
Old Jul 27, 2006 | 09:44 PM
Chris18927's Avatar
Default oil
i just got my z28 not to long ago and i need to change the oil. How much does the egine hold oil wise? my dad has a 350 in his cutlass and his holds about 5qt so thats how much i put in. Is that good or do i need more/less?
Old Jul 27, 2006 | 11:27 PM
GTP PWR's Avatar
I put 4.5 in then start the car for the engine to run through, then I CHECK the dipstick. I add maybe another 3/4 of a quart and I am above center of the cross hatches.
around 5. check the dipstick......
Old Jul 28, 2006 | 01:35 AM
buffman's Avatar
engine capcity should be 5 qts. I put 1/2 quart in the filter, and the rest in oil filler
Old Jul 28, 2006 | 12:33 PM
leadfoot4's Avatar
Are you using an "old stlye" 1 qt. oil filter (PF 35 Delco), or the shorter (PF 25 Delco) filter? That will make a difference. And, as Buffman said, fill the new oil filter before you put it on the car. It helps get the oil pressure back up quicker.
Old Jul 28, 2006 | 01:48 PM
lt197formula's Avatar
I put in five quarts and then a 1/4 of a quart or so more. Its what I have always done, learned it from my dad never had any problems.
Old Jul 28, 2006 | 02:25 PM
Chris18927's Avatar
I dont really know what oil filter im using. Iwent to discount auto parts and said "I have a 94 z28 and i need an oil filter" the guy looked it up and gave me a Purolator brand filter with the number L20049 on the box. I dont know if that tells u anything.
