Wire Mod
Old Jul 28, 2006 | 04:02 AM
Cammd95Z's Avatar
Default Wire Mod
Anyone ever do the Wire Mod to the Pass side wheel well?
Old Jul 28, 2006 | 04:05 AM
blown 346's Avatar
I did mine, it was easy and did a nice touch to the engine bay.
Old Jul 28, 2006 | 04:06 AM
Cammd95Z's Avatar
What did it involve?
Old Jul 28, 2006 | 04:11 AM
blown 346's Avatar
You have to disconnect the battery, take out the wheel well cover,disconnect the wire harness, re route the grounds on the passenger side strut tower under the wheel wheel. I used a 1 3/4 bi metal hole saw so i could fit the harness through the hole you have to cut. Cut a hole in the back of the strut tower, route the harness throught the hole, re connect the wires. I used electrical tape to wrap mine up, I used the existing clips on the harness and snapped those in place throught the two holes in the strut tower.
Old Jul 28, 2006 | 04:15 AM
Cammd95Z's Avatar
How long did it take you from start to finish?
Old Jul 28, 2006 | 04:18 AM
blown 346's Avatar
It took me about a hour and a half to do, I wanted to make sure I drilled the hole in the right spot the first time around. Now if I were to do it again, I could proabably have it done in a hour.
Old Jul 28, 2006 | 04:21 AM
Cammd95Z's Avatar
something im going to look into doing anything that can help clean up the engine bay on these cars will help
Old Jul 28, 2006 | 04:24 AM
blown 346's Avatar
It makes it look completly different, Mine look cluttered before, now it is all open and clean. I would definitly do this, it is easy and can be done by anyone.
Old Jul 28, 2006 | 04:26 AM
Cammd95Z's Avatar
is there anything special you need to buy?
Old Jul 28, 2006 | 04:41 AM
blown 346's Avatar
The tools I used were, a 1 3/4 Bi metal hole saw, wire cutters for electrical tape and zip ties, zip ties, electrical tape, a drill.
The only real thing you might have to buy is the hole saw and a 1 3/4 rubber grommet.
Old Jul 28, 2006 | 02:40 PM
PipesTA's Avatar
Did it in about an hour, and did the latch cable in about 15 minutes
Old Jul 28, 2006 | 03:09 PM
Rocko71's Avatar
does anyone have any pics?
Old Jul 28, 2006 | 03:28 PM
harvickgm's Avatar
same here... i would like to see some before and after pics of the mods done...
this is very interesting... ive thought about doing that with another set of wires... but havent put much thought into it until now...
Old Jul 28, 2006 | 03:39 PM
PipesTA's Avatar
https://ls1tech.com/forums/appearance-detailing/173263-completed-wire-mod-tutorial-inside.html
Old Jul 28, 2006 | 03:43 PM
PipesTA's Avatar
https://ls1tech.com/forums/appearance-detailing/309397-hood-latch-cable-relocation.html
Old Jul 28, 2006 | 06:24 PM
blown 346's Avatar
The latch cable?
Old Jul 28, 2006 | 06:31 PM
Dragframe's Avatar
Originally Posted by blown 346
The latch cable?
For the hood.. waste of time IMHO... but then again only 15minutes for a lil cleaner bay
Old Jul 29, 2006 | 01:26 AM
Cammd95Z's Avatar
looks nice i will be doing both the mods this week
Old Jul 29, 2006 | 03:06 AM
Cammd95Z's Avatar
anyone heard of a fuel line mod to clean up other side??
Old Jul 29, 2006 | 03:17 AM
blown 346's Avatar
I havent but I would also like to do this, anyone have any info, or ideas???
The way the fuel line runs fron the driver strut tower, it could easily go on top of the back of the intake and then to the front of the car.
