Stock 1994 Z28 A4 bin.
Originally Posted by Commando
how do u upload these files into the car... using what program i mean??
Tunercats is cheaper, not vin locked, and you can do more but is more complicated the LT1edit. Edit is more user friendly but also vin locked.
Theres a winflash or whatever its called from Tunercats that you can use also. It's sole purpose is reading and uploading tunes.
Question, here's the situation. I swapped another engine into the Camaro and a stock tune from another car was installed. Does VATS have to be disabled? If it wasnt disabled would it allow the car start and run for a couple of seconds before dying?
#34
lt1 edit is a lot more user friendly, but tc isnt that hard really. read through this, and you can apply most of this into tc to figure out what everything does. tc has a few more not listed here, but the names of things are a little different ... dont need to be a genius to figure it out though!
http://www3.baylor.edu/~Christopher_...ht/LT1Edit.htm
