All CAI's Considered Equal??
K&N and Moroso are more or less the same, very good quality products, made out of plastic, so the heat soak is less than SLP, but thats not big a number, the SLP looks Bad *** Hands down.
--Alan
http://store.summitracing.com/partde...5&autoview=sku
Exactly like the SLP, looking at the weather condetion we deal with, the SLP is not an option for street cars and Daily diven cars, it will soak heat after Driving the car for some time and we have more or less the same heat as the engine bay, which defeats the porpose of investing in a CAI.
Have any one tried Forced cooling? Im not really sure what is it called, but I saw the guy at the shop installing the kit for a 06 stang, it was NOS.
I am not sure about the name, its using Nos, not being shot in the Intake manafold but its used to cool the air in the going in the system, so far I have seen 2 installed, a nitrus system on a 06 stang, and a CO2 system on a 05 E55 K3.
I currently have the Arizona Speed & Marine CAI now. This CAI uses a solid metal tube so securing the filter is much better. There is no possibility of the filter working its way off the metal tube like what happens on the non-rigid plastic tube. Another plus is the filter installs from the top throught the hole in the chassis so filter servicing is a cake walk. The AS&M is the most expensive CAI out there but when you factor in reliability and ease of servicing it is well worth it. I can remove the filter in less than two minutes with out having get on my back. These benefits can also be applied to the Moroso CAI as well. The Moroso is less expensive but it has the metal coupler that secures the filter tightly just like the AS&M plus the filter goes in the top too. I believe that these two CAI's for the LT1 are the best all things considered and provide the most piece of mind and ease of servicing.
I have read that many people who have the K&N have problems with the filter staying on, I think the plastic tube is not as reliable as the metal. I personally would not go hacking up the chassis to ease in the filter servicing. I would consider selling your K&N and going with the Moroso CAI or if you want to spend the extra dollars go with the AS&M. My AS&M is much louder in terms of the sucking sound than my Moroso was, im not sure if this is indicative of anything. This may mean it is flowing more air but thats another discussion. Also hacking up the chassis will not cure the issue with the filter falling off.
The AS&S does heatsoak a bit when sitting still at idle, but not when driving.
The two best in my opinion are the AS&M and the Moroso becuase of the metal tubing. I dont like the K&N due to the plastic tube where the filter attaches. The SLP is good but is a PITA to clean and maintain where the AS&M and the Moroso filters will pop out in less than a minute to clean.
Performance wise, I think they are all very close.
I've seen people use it on NA cars, but it's not as efficient as it would be on a FI car. My buddy has an alcohol injected '02 SS that's NA.
