how about this setup?
Old Aug 14, 2006 | 12:34 PM
94_lt1's Avatar
Default how about this setup?
*victory racing engines 383 sportsman shortblock
*LE3 heads/cam package
this is what im leaning toward on my build. do u all think this would be streetable? the cam in the le3 package? should i get a different cam or will this cam be the biggest i can go with and be streetable?
this all is going in a automatic trans car. the car is going to be pretty much gutted. what kind of numbers and 1/4 times SHOULD i see from this?
Old Aug 14, 2006 | 12:42 PM
94_lt1's Avatar
should i swap the le3 package for some custom grind cam and afr heads? or will the le3 package get me the same power?
Old Aug 14, 2006 | 03:53 PM
streetwarrior96's Avatar
stick with the L3 for the price
Old Aug 14, 2006 | 04:40 PM
aggiez28's Avatar
whats your budget for the motor?
Old Aug 15, 2006 | 12:12 AM
94_lt1's Avatar
i will spend 10k in engine alone if needed
Old Aug 15, 2006 | 12:42 AM
94_lt1's Avatar
anyone know the specs on the cam in the le3 package?
Old Aug 15, 2006 | 12:45 AM
Speed Density's Avatar
hashtagBMW
Dont follow the pack man, do something different.
Old Aug 15, 2006 | 12:52 AM
JUICED96Z
Guest
Posts: n/a
He only releases that when you buy the cam from him, if you buy it used you don't get them
The LE3 on a 350 is pretty much a race cam (made for a 383), LE2 is the way to go for a 350.
Do a search on www.camaroz28.com for LE2 and LE3
Old Aug 15, 2006 | 01:14 AM
94_lt1's Avatar
what u sayin? not build 383? something different?
Old Aug 15, 2006 | 02:03 AM
switch hit's Avatar
Sorry if the pack is the cheapest way to go for instance Lyoid Elliot heads, its the way to go. There isn't much else you can do with an Lt1 turbo,super or stroker W/spray your in the pack if you like it or not. Unless you have an 427 LT1 which is not very realistic to everyone
Old Sep 4, 2006 | 02:12 PM
Uthinkso's Avatar
Different cam and heads perhaps. Agreed that the above package makes great power, and is a proven one. I'm not sure what he meant bynot following the pack either.
Do you intend to use a power adder?
