LT1 Block interchange
Old Aug 15, 2006 | 08:59 PM
Dr. Teeth's Avatar
Default LT1 Block interchange
Are all the LT1 blocks that were made identical? So if Iwant to build a replacement engine for my 96 WS6 can I start with ANY LT1 block and build from there?
Old Aug 15, 2006 | 09:04 PM
dhdenney's Avatar
All Corvette blocks were 4 bolt main and the F-cars, others were 2 bolt. The 4.3 LT1 (or whatever it was) obviously isn't a good one to start with. But the 350ci blocks are all the same pretty much.
Old Aug 16, 2006 | 06:23 AM
Dr. Teeth's Avatar
So it's pretty safe to assume that I could build another bottom end and then pull my motor and transfer the upper end and so forth without much care for the year/origination of the new block?
Thanks.
Old Aug 16, 2006 | 08:11 AM
dhdenney's Avatar
I wouldn't think twice about it.
Old Aug 16, 2006 | 09:20 AM
Landon@Texas Speed's Avatar
Werd...all LT1 350 blocks were about the same...i got an impala block in mine..
Old Aug 16, 2006 | 09:22 AM
BarneyMobile's Avatar
I have a block out of a 96 vette.
Old Aug 16, 2006 | 04:21 PM
UA-Plumber's Avatar
The impalas came with either the 350ci LT1 or the 265ci LT1
Old Aug 16, 2006 | 04:23 PM
Honda Hunter's Avatar
Same here. If you can have it tested first Id do that but yeah I agree with what everyone else said
Old Aug 17, 2006 | 11:40 AM
GIZMO's Avatar
The Impala only came with an LT1. The L99 (265ci) was the base motor for the Caprice. The L99 was not available in station wagons.
Old Aug 17, 2006 | 06:44 PM
96capricemgr's Avatar
As GIZMO was saying the L99 was base in the Caprice sedan only it was not available in anything else. You guys can add 94-96 Roadmasters and Fleetwoods to the list of donors as the only engine offered for them was the LT1.
Old Aug 17, 2006 | 09:37 PM
Dr. Teeth's Avatar
thanks!
