True Duals?
Old Oct 30, 2006 | 02:12 PM
  #41
Fire67's Avatar
Originally Posted by ABA383
Performance Auto Fabrication,a local shop, does it with 3" with no problems, It's all custom and it ain't cheap, but its well worth it to have 3" duals and the Spohn TA...He's doing mine soon...
--Alan
I have the BMR TrakPak tq arm with the crossbrace and all. Im currently running a pacesetter ORY that I modded to merge into a 4" pipe. I did this for my mufflex 4" catback.
Im selling my catback and trying to design a true dual setup to work with that crossbrace.
Im considering using the existing y-pipe, and adding another custom y to the other end of the merge. Then running Dynomax bullets or Dynatech small ovals and turn downs in front of each rear tire. Expelling the exhaust away from the car to avoid residue buildup underneath.
Here's my question, for anyone knowledgible in the subject; Would the 4" merge flow well enough or should I ditch that y-pipe all together and get a true x merge?
Old Jan 26, 2010 | 02:02 AM
  #42
the_merv's Avatar
Veteran: Air Force
Here are my TD's..
Summit 3" X-pipe
Flo Pro Twistie Mufflers
Old Jan 26, 2010 | 04:06 AM
  #43
hitmanws6's Avatar
if you run it out back, you have a few options. you can do under the axle, over the axle or a combo of both (like Bassani does). 3" over the axle can be done with stock routing, but requires more work than going right under the axle
Old Jan 26, 2010 | 10:47 AM
  #44
R3DLT1's Avatar
Here is my set up bro
Deltas
Old Jan 27, 2010 | 09:37 AM
  #45
flyinZ's Avatar
ABA383, do you have any pics/vid of your setup? I've seen it before I think, and its a work of art
Old Jan 27, 2010 | 06:08 PM
  #46
95Z28420's Avatar
i have longtubes, high flow cat x pipe and 1 chamber race flowmasters...sounds amazing
