FINALLY!!!!!!! Edelbrock released LT1-LT4 intake
#181
Originally Posted by 96capricemgr
What I was saying is the late LT1 intake is closest to identical to the LT4, the earlier LT1 intake had more rectangular ports.
Only thing to watch with an LT1 intake on an LT4 is the sealing surface at the top of the port gets very narrow because the LT1 intake lacks material as compared to the LT4. That is why GM added material there not for port matching as others have said, true it does allow port matching an LT4 intake to LT4 heads but that is not what GM was thinking about when they cast a whole seperate intake.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#182
Hello, I'm new
to here, I own a 95 z28 with the t56 6 speed and the LT1 v8. I found a good website for the differences between the LT1 and LT4 in general, including the intakes. http://www.grandsportregistry.com/lt1vslt4.htm
According to that, the biggest difference is the material, along with the raised runners. The main reason the LT4 was better was head design, which is shown using a nice cross - section comparison.
Hope that helps someone.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#186
Originally Posted by 97Lt1TA
correct me if im wrong but wasnt at one point the lt4 intake when still produced and sold at summit for around 400 dollar range. $537.95 seems kinda high but i might be wrong about lt4 being around 400 dollars at one point brand new
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
#187
Mike
#188
If things are actually this close to being down to the wire, does anybody find it a bit suspicious that Edelbrock hasn't released any info regarding dyno tests for this thing? I mean, if they've gone as far as to authorize vendors to start taking people's money, even if they miss their target ship date they've still gotta be pretty damn close to being released. This intake debuted at SEMA 2005: two years ago. I find it very hard to believe that in that timeframe they haven't had an opportunity to get some baseline dyno #'s established.
Last I checked, (correct me if I'm wrong), both Lloyd Elliot and Advanced Induction offered full race ported stock intakes for $225. You can bolt on 30-40HP with a set of ceramic coated Pacesetter longtubes and Y-pipe for around $500.
For $537, this intake had better make an LT1 walk on water.
#189
They told me that at the earliest it would be available would be March, but probably later.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
#190
Originally Posted by Ponyhntr
The reason they don't have any dyno numbers for it yet is that they don't even have a WORKING prototype yet! Last talked to them about a month ago (I somewhat have an inside connection there), the intake was still in 'Stage A' which means it has a part number, nothing else. Yes, they have a few display pieces, but those are not production pieces.
They told me that at the earliest it would be available would be March, but probably later.![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
http://store.summitracing.com/partde...5&autoview=sku
#191
Originally Posted by onephatZ28
Summit did the EXACT same thing with the MSD Optisparks. They were 'selling' them on the website LONG before they ever got one to actually ship out the door.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
