New Stocker
Old Oct 7, 2006 | 08:32 AM
  #41
GIZMO's Avatar
Originally Posted by stroked30th
What front hub do you run? Does that have to be stock?
Back in go-kart days we'd take the grease packed bearings apart, clean them and then just use white lithium or WD-40. Helped rolling resistance, but had to keep a very close eye on them.
The hubs are OEM. I have go-kart buddies who do the same trick. I'm not sure how well the bearings would hold up with 800 lbs on them? I have thought about using an aluminum hub to reduce rotating weight. Maybe on the next car. This one is a little more low buck.
Daren
Old Oct 7, 2006 | 04:53 PM
  #42
GIZMO's Avatar
The front suspension.
http://i85.photobucket.com/albums/k5...1/DCP_1449.jpg
Old Oct 8, 2006 | 09:24 AM
  #43
GIZMO's Avatar
What do you do for a gauge assembly?
I just noticed that your car is a Camaro. Here is a picture of my old Camaro. You can see that I mounted the guages on the pillar. The oil is mechanical and the temperature is electrical. The other guage is volts. The tach is on the dash. Because I run stock eliminator, I try to keep the interior as stock looking as possible.
http://i85.photobucket.com/albums/k5...1/DCP_0128.jpg
Other Camaro pictures.
http://i85.photobucket.com/albums/k5...1/DCP_0304.jpg
http://i85.photobucket.com/albums/k5...1/DCP_0312.jpg
Old Oct 10, 2006 | 10:54 AM
  #44
GIZMO's Avatar
New back brakes are installed!
http://i85.photobucket.com/albums/k5...1/DCP_1450.jpg
Aluminum drums.
http://i85.photobucket.com/albums/k5...1/DCP_1451.jpg
Wheels and light weight radials.
http://i85.photobucket.com/albums/k5...1/DCP_1452.jpg
Note that the parking brake and self-adjusters have been left off.
Old Oct 10, 2006 | 10:59 AM
  #45
stroked30th's Avatar
Why drum?
Old Oct 10, 2006 | 11:22 AM
  #46
GIZMO's Avatar
Why drum?
1. I just wanted to try some.
2. Low drag.
3. They are cheaper than aftermarket disks.
4. Having all of the parts laying around didn't hurt my decision process either!
Daren
Old Oct 10, 2006 | 12:19 PM
  #47
Shon Herron's Avatar
Any weight savings?
And if this come out of a 3rd gen then the axles are a tad bit shorter, does that help any?
I have considered going to the drum set up on my 4th gen....hmm...I could be that much closer to a stocker!
2. Low drag.
Daren
Old Oct 10, 2006 | 10:36 PM
  #48
GIZMO's Avatar
Originally Posted by Shon Herron
Any weight savings?
Shon,
Any time that you can cut rotating weight it helps. I will weigh some old disks that I have and some aluminum drums and let you know the difference.
The axle was built for a 1982-92 F-body. It's quite a bit lighter than one for a 1993-2002.
With what you have done with your stock internal LT1 you should build an IHRA Pure Stocker.
Daren
Old Oct 11, 2006 | 04:38 PM
  #49
BigBronco's Avatar
Originally Posted by Speed Density
Whats so cool about a stock LT1 in a race car?
Honestly sounds fun, im just confused...
Tony.
That is the point of Stock Eliminator. Same with Super Stock, just different rule set. We hold the D/SA record with Charlie Ford's 68 Shelby Mustang Stocker. 10.38's at 128 mph
Old Oct 11, 2006 | 04:56 PM
  #50
Ed Wright's Avatar
9-Second Club
That's a great running little Mustang! Very impressive car! Didn't know we had any celebrities on here.
Old Oct 13, 2006 | 12:33 PM
  #51
Lt1CamaroSS's Avatar
did you use a tighter spring for the rear drum brakes? and where did you get the alum drum from?
Old Oct 15, 2006 | 07:23 AM
  #52
GIZMO's Avatar
Because I eliminated the parking brake and self-adjusters I had to use two hardware kits. I also used the large bore wheel cylinders. The aluminum drums came on Grand Nationals and some other 1980's cars.
Take Care,
Daren
