i need help please!!!!!
Old Sep 12, 2006 | 09:07 PM
gsxkid's Avatar
Default i need help please!!!!!
ok here goes. i have a 94 lt1 6 speed.i pulled my motor out to do a fresh rebuild. i knew i would have a lot of down time. so i pulles my dash out and deleted all the havc stuff and my pass air bag.i put my motor back in and i went to start the motor and nothing. so i checked the the wires going to the starter. the big wire is a +wire the little wire is a ground.i am getting good power to the big wire but no ground at the little wire.i also noticed that mt door locks are not working and my trunck pop isnt working either.any suggestion please help thanks
Old Sep 12, 2006 | 10:45 PM
dhdenney's Avatar
Seems like there is a big ground strap on the passenger side of the block that bolts on a motor mount. Is there a problem with that wire?
Old Sep 13, 2006 | 12:15 AM
harvickgm's Avatar
first.. the ground strap should go to the body.. and second the starter grounds itself.. that purple wire is supposed to be on the solenoid... that is what gets teh signal from your key... make sure you didnt mess up the VATS system and then go from there.
Old Sep 13, 2006 | 04:25 PM
gsxkid's Avatar
i checked that ground wire its hooked up fine.i am afraid the alarm sys is not working propley.is there any way i can bypass the alarm?
Old Sep 13, 2006 | 11:00 PM
dhdenney's Avatar
That's just where mine was when I took the motor out. There's no telling what someone else did before I had it.
Old Sep 14, 2006 | 12:50 AM
harvickgm's Avatar
ohh i wasnt saying anything about it... thats just where i have seen most go.. but that bolt would go throught the body as well...
just ****** everything out that has to do with the alarm... unless they did the retarded way and cut and splice... then you have a project on your hands..
Old Sep 14, 2006 | 06:20 PM
gsxkid's Avatar
will lt1 edit bypass the alarm?
