Did a tune up!
Did a tune up!
Through in some AC Delco 906s, and I believe the old ones were original. Not an easy task but the use of the hoist at work was mighty helpful. took about an hour and fifteen minutes and the car seems to run smoother and stronger.
all the plugs I pulled out were at least .060 gap or greater.
he said the ones he PULLED OUT were at .060, not the ones that went in. It took me about 1.5 hours to do in the roomy cadillac under hood. and like you said, my platnuim stock plugs were all at .060-.070. Even replacing with just autolite coppers (104) really helped.
well remember a copper plug will make the most power even though you might have to change them every 30k
it took my about 2hrs last weekend, to pull all 8 plugs and do a compression test
