Please Help, backfiring through INTAKE?
Old Sep 16, 2006 | 11:36 PM
96formular's Avatar
Default Please Help, backfiring through INTAKE?
Hey guys need your help, car suddenly died and wont start.
Ive changed opti twice before (had warranty on Opti) and symptoms were the usual - would backfire out of exhaust, misfire, sputter.
Although now its backfiring through the INTAKE, seems like timing is off but
i need your opinion on what could be causing this.
Could the opti cause it to backfire through intake?
And could it be bad gas? (ACCIDENTLY filled up 87 for the first time 6gals. )
Will let you know more indepth tommorow as in if im getting spark, fuel (battery died im waiting for it to charge).
Thanks
Arthur
Old Sep 17, 2006 | 12:47 AM
96formular's Avatar
almost forgot
car is
96 Formula 6 speed
138k
no muffler, k&n cone.
other than that its stock.
Old Sep 17, 2006 | 12:55 AM
nemanracing's Avatar
my bad opti caused it to backfire back out the intake... fixed the opti, fixed the problem...
Old Sep 17, 2006 | 12:48 PM
AriveBlue04SS's Avatar
Had same problem on brothers 93 z28 and it ended up being coolant temp sensor.
Old Sep 17, 2006 | 12:55 PM
onebadblackz's Avatar
mine was doing the same took the MAF off and its fine!!!
Old Sep 17, 2006 | 01:15 PM
96formular's Avatar
thanks for the info guys, keep them coming.
Ill replace coolant temp sensor just to be safe.
If its the Opti ill try to get a refund and order the Accel opti.
Ill provide details tonight, didnt get a chance yet.
Old Sep 20, 2006 | 10:11 PM
96formular's Avatar
well you guys wont believe what it was, after removing the Opti
i found out that the 2 Bolts that hold the rotor together magically
unscrewed . No damage was done at all, they just unscrewed and
rotor was just sitting in one spot, so i bolted it back up and put couple
drops of super glue on them just incase.
Well thanks everyone for the help, im very fortunate to get out of this
repair without spending a dime .
Old Sep 20, 2006 | 10:22 PM
I shoulda been more clear in my previous post... This is the same thing that happened to me... I put it back together using a lil red loctight and haven't had a problem since...
Old Sep 21, 2006 | 01:08 AM
96formular's Avatar
I didnt think of that, I already sealed the opti.
I did the same thing i did last install put high temp silicone around the rubber seal neatly, its easy to take of if i have to open it and there was zero moisture or oil in the opti when i opened this time.
and nemanracing you posted about 30 min after i sealed the opti .
Im pretty sure its not gonna cause me any problems though.
Heres some pics after i sealed it, does any one else do this?
or am i the only one .
Old Oct 20, 2023 | 05:05 PM
Kc8223's Avatar
Default Started back firing randomly
Car started backfiring randomly after accelerating onto the insterstate and now it won’t start, what would cause this to happen?
Old Oct 23, 2023 | 12:29 PM
SS RRR's Avatar
Village Troll
Opti rotor could be loose. There are tiny screws which hold the rotor in place and they have been notorious for backing out causing the rotor to fire cylinders at will. You'll have to take it apart to see. Requires somewhat special tools like inverted star screws. For simplicity you can use one of the star bolts off the top throttle body cover. Search on this forum. Many many threads about this very thing.
