anyone have an LT1 shop manual? what is the pressure that sets off the bypass valve?
And if you do, could you do me a favor and look up something? I'm curious as to what is the pressure that sets off the bypass valve for the oil filter. I know on GM cars the bypass valve is built into the block, instead of relying on one
that is built into the actual oil filter.
Re: Does anyone have an LT1 shop manual?
I have one at home for my 94Z. I'll see tonight if I can locate the pressure rating.
I tapped and plugged my bypass hole with a bolt & loctite red. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I want ALL the oil to go through the filter. I also ditched my factory cooler.
-Andrew
-Andrew
Are you sure you want all the oil to go through there? If a filter gets plugged up somehow, that bypass valve could save your motor. Plus, on a cold start you want the oil to bypass the filter to avoid damaging it. Cold oil (even in the hot summertime) can create a lot of stress inside an oil filter and could burst it.
Did you check the manual for me yet Andrew? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thoughts on where any values for that pressure would be?
I looked in the engine section. It did mention the bypass, but it did not give any specifics at all about it.
-Andrew
-Andrew
Maybe they don't go into any detail on it in the manual? I figured the manual would show something on it, especially in case that part ever fails.
