Which oil pan for 2pc main block?
Old Dec 16, 2002 | 09:16 PM
Don Lindsey's Avatar
Default Which oil pan for 2pc main block?
Does anyone have any idea which oil pan will clear everything in our engine bays and fit an older, 2pc rear main block? Oil level fittings and such are not a concern.
Thanks!
Don
Old Dec 17, 2002 | 07:52 AM
The Big Show's Avatar
Default Re: Which oil pan for 2pc main block?
Are you using the stock cross member or a tubular aftermarket piece?
Old Dec 18, 2002 | 02:05 AM
PA Racing Tubular k-member.
Old Dec 18, 2002 | 02:06 PM
JB_Manning's Avatar
Canton has a pan that will fit...
Canton 15-120 (for pre-80 blocks with left side dipstick)
Canton 15-120M for 80-85 blocks with right side dipstick
T-sump pan, 7 1/2" deep... 7 qt system capacity (with 1 qt. filter)
JB
Old Dec 18, 2002 | 09:13 PM
I know canton makes a couple pans, but I used one of their pieces on my old LT1 motor and I wasn't very impressed.
I found them to be overpriced and under-engineered. It was poorly finished and I had leaking problems to no end. I'd much prefer to use a Milodon or similar pan. I've had FAR better success with them.
Thanks,
Don
Old Dec 20, 2002 | 12:38 AM
JB_Manning's Avatar
To each their own... I haven't had any problems with sealing on this pan. Didn't require any clearancing for a 3.875" stroke either... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Just giving you some options....
You can also use those specs to get an idea of what will fit, whether it be a Moroso, Milodon, etc.
The 15-120 pan specs are:
7 1/2" Deep
9 1/2" Long Sump
10 1/2" Wide Sump
The 15-244 pan is:
7 1/2" Deep
12" Wide
8 1/4" Long
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
JB
<small>[ December 19, 2002, 12:46 PM: Message edited by: JB_Manning ]</small>
Old Dec 21, 2002 | 02:09 AM
Gangly's Avatar
wussup JB, glad to see you on here, nice to have another well LT1-educated member on the site :-D
Old Dec 23, 2002 | 01:15 AM
zturbo's Avatar
I personally like my stefs and will be getting another. On a side note the three canton pans that freinds had all leaked. I have heard many others that love theirs though.
Steven
Old Dec 24, 2002 | 01:02 AM
Which stefs pan did you have?? Do they make one in the same configuration for 2pc rear main??
Thanks!
Don
Old Dec 24, 2002 | 05:12 PM
zturbo's Avatar
I have the basic one right now I got options of the stroker crank areas enlarged, and for the f-bodies. I will be getting another as i am selling my motor. They make it for the 2 piece. Go to there web site they have some listed or call them up. Stefs
