Lt-1 wiring codes for a 94 Camaro/Caprice motor
Ok guys Im doing a motor swap from a 4.3L CPI in a 94 Blazer to a 94 LT-1 Caprice motor I pick up for $800(not bad huh?). I need to know some wiring harness codes for a 94 Caprice or Camaro. I got alot of the basic ones like the big red 10 Gauge wires are for the constant power. I know the 4 wire big plug with the 3 10 gauge wires is for the fan(s). Yellow is starter, pink
=ignition, etc, but i need the others. Like all the small wires that arent readily or easy to trace.
