View Poll Results: Which thermostat should I have?
Mr. Gasket 160
8
22.22%
Hypertech 160
23
63.89%
Stock thermostat 185
5
13.89%
Voters: 36. You may not vote on this poll
Mr. Gasket 160 thermostat over hypertech?
I've had my 160* Hypertech in for about 4 years now. I pulled it out a couple of months ago for an EWP install. While I had it out I tested it and it seemed to be opening a little slower and at a higher temp then it should have been. When it's in the system under heat and pressure it may be right on though. I may replace it just to be sure. I would not hesitate to buy another Hypertech.
Is this a 160 deg for a reverse cooling LT1? I've been looking local but most just sell the 180 deg LT1 stats. Failsafe also? I'f so I'm heading to autozone.
#32
I'm not sure about failsafe (It does look identical to the picture above), according to Autozone it's a "stock replacement, alternative temperature" thermostat. But if it's a Motorad, same as all the high priced ones, I can't see that it wouldn't be. There's no way they would make two separate ones.
#34
I ghot my hypertech 160 in my car, and got the fans tuned. my car nevers even touches 170 degrees now.
so far, I havent had problems with it....except it blow barely warm air when I got it on full heat
