leaking head studs
Old Oct 10, 2006 | 07:20 AM
fast92lt1rs's Avatar
Default leaking head studs
Well yesterday was great. I am pulled the 94 383 out of my 92 to put it in a different car and I drain the oil out of it and no joke it looked like peanut butter and actually hesitated to come out of the drain plug. At first I thought I had a bad head gasket but then saw that I had coolant seeping up around the threads of the head studs. I think that they might not have sealed where they go into the block. The guy at the machine shop that bored the block said that when installing head studs use pipe joint sealer on the coarse threads that go into the block to seal them and only tighten them to the point that you can't turn the stud any more. Then after putting on the head apply the torque to the nuts. Is this the correct procedure? He said if you torque the stud into the block then torque the nuts you will break either the block or the studs. This engine has less than 100 miles since being rebuilt as a 383 and I hope nothing is damaged due to all the water in the oil. Oil pressure has never gone below 30 PSI. Any recommendations?
Thanks
Pete
Old Oct 10, 2006 | 07:44 AM
GIZMO's Avatar
If you have had that much water in the oil the motor needs to come apart. What type of thread sealer did you use? If you used regular plumbers pipe dope you did the wrong thing. You need to use a good Teflon thread sealer.
Daren
Old Oct 10, 2006 | 07:57 AM
Yeah this guy said to use regular pipe joint sealer. What do you recomend. As far as the engine should I tear it apart inspect the cylinders and replace all the bearings? I am a Navy diesel mechanic. I am used to working on engines the size of our cars. Before this discovery it was running strong with no smoke, no overheating and great oil pressure. Never below 30 lbs.
Thanks Pete
Old Oct 10, 2006 | 08:07 AM
Tony Shepherd's Avatar
Thats a common problem. Some engines have no issues and some will. I used BARS heavy duty stop leak in the radiator. The kind with the pellets. Ran the engine for about 3-4 heat cycles and the leaks stopped.
Old Oct 10, 2006 | 08:09 AM
GIZMO's Avatar
Pete,
I use Loctite brand "Thread Sealant With Teflon". Part number 30561. It is about thirty dollars for 16 ounces. Available at a lot of plumbing or industrial supply houses.
With as much water as you have said you had in your motor I would tear it all the way down. Inspect everything and replace anything that is suspect. Clean everything.
Good Luck,
Daren
Old Oct 10, 2006 | 08:36 AM
ToxicTA's Avatar
I used ARP teflon thread sealant when I assembled mine. There head stud installation sounds correct as per your description. You also mention coolant and water in your post. If water gets into your oil it is not as damaging as coolant. If it was mine being that it is out I would disassemble it and make sure ever thing is clean and ready for the use you plan on getting out of it.
Old Oct 10, 2006 | 09:04 AM
captaindbol's Avatar
Quick question. Do you by chance have a four bolt cap conversion? This is a much more likely scenario for a crankcase full of water. On some blocks you can't help but tap into water on the outer bolts but the scary part is that a hole may often apear blind but have a opening into the water jacket. For this reason we always use thread sealer on the outer bolts.
Old Oct 10, 2006 | 11:51 AM
Thanks for all the replys. Yeah, to be on the safe side I will tear it apart and chech everything, and use the ARP sealant. Captain, no it is not a 4-bolt conversion. Just 2.
Thanks for everything.
Pete
Old Oct 10, 2006 | 02:34 PM
triumphman's Avatar
I have built alot of sbc's and i can tell you studs will always leak when they screw into the water jacket they are VERY hard to seal. Do yourself and your engine a favor and use a high quality head bolt ,you wont be sorry ,filling your engine with coolant is disasterious! Studs are made to use with blocks with blind head bolt holes i.e. GM bow tie/dart /brodix/wp.......
Old Oct 10, 2006 | 02:53 PM
You know what, I just got off the phone with a local speed shop and the guy I know there said the exact same thing. I think I'm going to go with a bolt kit from the ARP High Performance Series. He also said that they see the gooey coolant/oil on LT/LS1 's all the time. I am going to replace all the bearings as well. It's sitting on a stand. I'd be stupid not to.
Thanks all
Pete
