LT1 pull from top
Old Oct 11, 2006 | 08:35 PM
xxxtreme36's Avatar
Default LT1 pull from top
Does anyone have a decent writeup or know of anything i can use to make pulling the motor from the top easier. I know its going to still be PITA but im not doing the cradle drop. I tried the search and didnt come up with much.
Thanks
Old Oct 11, 2006 | 09:12 PM
Quick96ss's Avatar
I did mine out the top. Go on TPIS.com website and buy the Happy Hooker for 40.00 it is easy with that. The rest is th same start to disconnect things. Be Aware of your oil pressure sending unit on the back of your intake take it off before you pull it or you will brake it and it cost 35.00. It does suck to do but take your time and make sure you have a buddy ther to help. Pm me if you have any other questions i also have pics to help you get and idea of how it came out.
Old Oct 12, 2006 | 01:52 AM
LS1 Eddie's Avatar
I did mine from up the top. It's doable. Just be paticent. I have heard that that happy hooker thing is nice to have. I think if I were to do it again (God forbid) I would go out the bottom though.
Old Oct 12, 2006 | 08:51 AM
moserman's Avatar
i did mine through the top WITH the oil pan on AND the intake manifold, you just have to tilt the block sideways and angle it in properly, like is1eddie said, just be patient because it is time consuming.
Camaroholic's Avatar
This post comes up about once a month, eh?
http://www.akmcables.com/l99.htm
There's a Happy Hooker in action. It makes it easy.
I did my last swap out the bottom, because I was putting Eibachs and Bilsteins on at the same time. I must say that I think the top was easier, if just doing an engine swap. You don't have to disconnect the brake lines or mess with the power steering. Less fluid slopping around.
Old Oct 12, 2006 | 10:01 AM
wrd1972's Avatar
Dumb question.
Are you guys pulling it out with the tranny attached or not?
Old Oct 12, 2006 | 10:32 AM
95 N2OT/A's Avatar
why would you pull it out the top? the car was designed around the idea of droping it out the bottom
there are 11 bolts holding the entire tranny/motor combo in there are 5 on the tranny and 6 on the k-member. i pull these motors all the time and can drop the entire combo out the bottom in under 2 hrs using nothing but (2) 3 ton jack stands, a craftsman 3 ton jack, and a craftsman motorcycle jack. just jack up the car, put the motorcycle jack under the motor, and take out the 11 bolts. it's very simple just unhook eveything that catches on the way out (aka brake lines, tranny lines, coolent lines, swaybar brackets, and other little misc stuff)
i tried the out the hood way a few months back and wound up getting pissed off at the situation and droped it out the bottom anyway. it's just to convient
just my 2 cents
thanks
robbie
Old Oct 12, 2006 | 01:34 PM
burnzilla's Avatar
You want to take it out from the bottom.
Old Oct 12, 2006 | 03:44 PM
xxxtreme36's Avatar
hey i appreciate the info on both ends. But im going top, thats why i asked. I do not want to remove any brake lines and deal with that mess. Not to mention i only have a 1 1/2 car garage to do this with. I have a friend that pulled his out of his formula from the top by himself in 3 hrs. Just getting opinions and thanks again
Old Oct 12, 2006 | 03:50 PM
Speed Density's Avatar
hashtagBMW
Did mine from the top in 20hrs.
Tony.
Old Oct 12, 2006 | 05:14 PM
95 LT1's Avatar
just be patient.. its easy
Old Oct 12, 2006 | 06:31 PM
Bad Dad's Avatar
I pulled mine from the top using the happy hooker. I didn't have the height to
drop it out the bottom in my garage.
If you send me a deposit your welcome to use my happy hooker.
Shoot me a PM if interested.
Kevin
Old Oct 12, 2006 | 07:04 PM
the_merv's Avatar
Bottom here, took a total time of 7 hours myself. That's taking the Engine off of the K-Member, and putting the car back together to transport it.
Old Oct 12, 2006 | 10:04 PM
xxxtreme36's Avatar
hey Bad Dad i may take you up on that offer of yours
Old Oct 12, 2006 | 10:14 PM
DroppedM6Z's Avatar
i'm doin it right now.....not hard at all
Old Oct 13, 2006 | 06:38 AM
94Z28Joe's Avatar
i just did mine pulled it from the top with tranny. didn't take long at all put it back in without the tranny attached.
Old Oct 13, 2006 | 06:55 AM
Bad Dad's Avatar
No problem shoot me a PM when your ready.
I pulled mined with help from my 10 year old.
Was not difficult.
Old Oct 13, 2006 | 06:56 AM
Bad Dad's Avatar
Wow I didn't think there was enough room....auto or manual?
Old Oct 13, 2006 | 09:54 AM
xxxtreme36's Avatar
hey dropped whyd you remove the heads and everything to just pull a block? seems like if your going to pull it itd be easier to yank the heads and whatnot on a stand. Just wondering. Any tip and tricks guys let me know
Old Oct 13, 2006 | 11:27 AM
drewl's Avatar
i got mine out in about 2 hours, with tranny attached. no happy hooker, no hood.
then again, it was only half cut so i didn't care about damaging the car
sawzall makes it QUICK!
