Best Header Gasket for LT1
Also check the header bolts shortly often to make sure they are all tight and that they stay tight.
Far as not checking because you have good bolts, well it is not the bolts that loosen the gaskets compress first which can lead to bolts loosning but the bolt loosening is a symtom not a cause.
. Put them on and forget about them
