First time on the dyno and the last time for a while
First Pass 272hp 314tq. (On Motor)
I was happy with these number AFR was around 12.6
Second Pass (On Bottle) BOOOOOOOOOOOOOOOOOOOMMMMMMMMMM
As soon as he hit it my car blew black smoke out like it was a diesel and then a sound that was like a shotgun going off by my head. I ran to my car and look down at the engine and all I saw was oil just pooring out of the pan!!!!
I was so pissed off. It appears that it shattered a piston and broke the rod in half which is what put a huge hole in the oil pan.
So now I am going to build a 383 for it and I have been looking for kits and was wanting an opioion on what kit to buy.
I saw that Victory has a Eagle all Forged for like 1400, or I can get the Victory kit with the dragonslayer crank, callies rods, and JE pistions. What one will hold a 250 shot better. I figure if I am going to build it I am wanting to do it the right way.
Also what size cam would you guys recommend. I am really wanting to biuld a low 11 high 10 car. I already have a great set off heads ready for it just not sure what cam to put in with them.
Any and all opionins wanted.
Thanks
James
"ABA 383" I have been following your progress...Congrats on 11.3's run...With cooler spring weather maybe high 10's. I hope to get mine back out at the track this weekend(weather permitting). Last time second gear was dead due to fuel pump going bad...Hopefully, I can pick up another 1/2 second...
--Alan
I am putting in Forged Pistons and Rods, they should hold up to Spray if I wanted to hit them with it. I am just putting back in a 350 though..
As far as a 383 the options are endless. As long as you do the research you should be able to build a 400 HP easily and then add the additional NOS. Remember to spend the money on the forged internals and pistons so it doesn't happen again.
Good Luck
Oh thats why you always bring a video camera to the Dyno...
I am just building the LT1 back to a 350, and running with that. Something simple on the street. I did Port my Heads, and it is running quick for what it was already.
