Valve covers
Old Oct 18, 2006 | 02:46 PM
Quick96ss's Avatar
Default Valve covers
What valve covers are you guys running with Pro Magnum rocker arms???
Old Oct 18, 2006 | 02:53 PM
streetwarrior96's Avatar
stock
Old Oct 18, 2006 | 03:01 PM
rasputin's Avatar
I was gonna ask this yesterday after trying to put on my stock covers. I did a search and found out that you can simply modify them. I only read this, but seems rather intuitive, I wish there were pictures though...anyways, those supports that attach to the holes where your covers bolt down in between the rockers, I guess you can use a pair of pliers and bend them down so the rockers can clear them. Apparently takes only a few minutes to do. Then that black box which is the oil something or other, I guess you can crush that with the pliers as well and it should fit.
Hope that helps, I am gonna be doing that this weekend. If anyone wants to chime in with pictures, that would be great!
Old Oct 18, 2006 | 03:10 PM
Quick96ss's Avatar
i bought a pair of canton valve covers but they dont fit with my SS intake so i tryed to midafy them and it didnt work i also had trouble fiting the altenator.
Old Oct 18, 2006 | 05:14 PM
buffman's Avatar
Stock and mine are just fine bend the suppors like mentioned and crush the oil seperator/black box/whatever you want to call it. when you remove the cover and look at the supports you 'll see how the bracket is "L" shaped. Just bend them straight.
Old Oct 18, 2006 | 05:27 PM
Formula350's Avatar
Crane 1.6 RR do the same to the valve covers with?
Will the centerbolt Edelbrock covers work/work better? I have a set of those on another motor I can use.
What about the Vette molded plastic? I like the squarish look of those.
Old Oct 18, 2006 | 05:35 PM
rasputin's Avatar
perfect, thanks for the help!
