Rear main Seal
Old Oct 19, 2006 | 01:47 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
Default Rear main Seal
How big of a job is it to replace a rear main seal on my lt1? Any walk throughs out there on the web? TIA
Old Oct 19, 2006 | 06:33 PM
zlover129's Avatar
with the tranny on, impossible
Old Oct 19, 2006 | 07:09 PM
hotrod18_69's Avatar
= ( you have to pull the trans just to get to it.. Once you get it out, its right there behind the Flywheel/Flexpate.. Can't miss it..
Old Oct 19, 2006 | 07:10 PM
Razor_Blade's Avatar
Can it be done with the trans removed?
Old Oct 19, 2006 | 07:11 PM
the_merv's Avatar
It has to be done with the Trans removed, no question about it. You have to unbolt your Flexplate/Flywheel to get to it.
The next question is if it's installed wet or dry..
Old Oct 19, 2006 | 07:52 PM
zlover129's Avatar
yea, once you take the tranny and stuff out (which isnt terribly difficulty assuming you have a lift or something) then its a piece of cake, just ubolt the back of the oil pan and inbolt the thing surrounding the rear main seal, then install the new one
Old Nov 4, 2006 | 07:33 AM
PoorMan's Avatar
Default :)
The rubber Felpro says to install wet. The permatex Felpro says to install dry.
I am doing this today so I just read it after opening both boxes at the store.
JD
Old Nov 4, 2006 | 03:46 PM
the_merv's Avatar
I got it in wet, lubed it with assembly lube.
Old Nov 23, 2006 | 02:26 PM
themadspoon's Avatar
Will lubing it with oil do the trick?
Old Nov 23, 2006 | 02:37 PM
Revelation Z28's Avatar
KY jelly works best on some things. im serious too, i used it on my front sway bar bushings.
Old Nov 23, 2006 | 02:54 PM
When changing the rear main seal there are 3 bolts and 1 nut that you take off then you must take off the two nuts facing downward and what else to remove the seal?
Old Nov 23, 2006 | 03:01 PM
seawolf06's Avatar
What seal would you recommend?
