How to install one of these *pic*
That's my new project also, since I have the room on the Fire Wall, I am goin to move it up there, unless you all think the Heat might mess with it..
duh... Did you even read what I wrote? take the line TO the booster. The reason you add one, is because you have a cam that has low idle vacum that causes the brakes to be less effective at a stop light. COME ON Merv... the stock canister works great for a stock idle vacum, but for a cam with less, you need more volume to make up the difference. Trending Topics
duh... Did you even read what I wrote? take the line TO the booster. The reason you add one, is because you have a cam that has low idle vacum that causes the brakes to be less effective at a stop light. COME ON Merv... the stock canister works great for a stock idle vacum, but for a cam with less, you need more volume to make up the difference.If you're running a large aftermarket cam which produces little vacuum, these aftermarket tanks are typically the solution. If THAT isn't enough, then you perhaps need to look into electric/mechanical vacuum pumps.
After that, your options are limited -- pretty much left with trying to convert to a non-vacuum-assisted master cylinder setup (which might prove difficult or impossible), or I've also seen these "Hydroboost" brake system boosters which run off of the power steering pump (which might be a better solution than the former, yet more expensive).
