True Duals vs. Cat Back...
My exhaust is currently Kooks stepped 1 3/4-1 7/8 LTs, Kooks 3" off road Y, and Borla cat back...Anyone done a similar swap and have track results to help me decide if its a worthwhile swap? Thanks...
--Alan
274.5 HP / 306.4 TQ
Pacesetter Longtubes and TSP X-pipe (3" dumped in front of axle) :
282.1 HP / 319.7 TQ
Motor was stock SS with Hypertech programming. Probably not a big help at your level but, what the hell...
After hearing of your car running so well and driving to the track, I will give you my honest oppinion on going from a Y-pipe to true duals.
If you want your car to remain enjoyable and "streetable" keep your setup. True duals are very loud and low.
I had a Y pipe with a flowmaster exhaust behind it and gained 33 rwhp by opening the cutouts right off my headers. I could drive the setup anywhere and the car was very streetable. In an attempt to get that hp gain all the time I went to a summit X pipe with bullit mufflers dumping at the axle.
While it gained plenty of hp (25-30) over my closed cutout y pipe setup, it is far less streetable. It is very loud and leaves me with maybe 3 inches of ground clearence. The car made a giant step into race car territory by swapping the exhaust.
Another thing to consider is that a chasis mounted torque arm will be tough to clear with true duals. My x pipe had to be extended and bent in all sorts of ways to get around the mount (part of why it is so low). If you are running one, it will make true duals interesting.
If you want an exhaust that won't have these problems you will likely pay a huge amount for a custom one.
I would put a cutout off your primaries and pull the catback out at the track for weight reduction. It would leave it streetable.
Also I'm trying to get a dd just not enough money right now lol
--Alan
--Alan
...its Performance Auto Fabrication and he did a guy's on here not too long ago...A red SS out both sides...
