best shift kit?
Old Oct 30, 2006 | 11:03 AM
25th trans am's Avatar
Default best shift kit?
wanted to know what the best shift kit one could buy for the 4l60e?
Old Oct 30, 2006 | 11:34 AM
mattraypharbor's Avatar
transgo...
Old Oct 30, 2006 | 12:41 PM
BlackScreaminMachine's Avatar
Internet Mechanic
I used trango, never an issue!
Old Oct 30, 2006 | 12:50 PM
Internet Mechanic
you can set them up, alot depends on your power, line pressure and converter. Mine was real nice.
Old Oct 30, 2006 | 12:52 PM
the_merv's Avatar
Veteran: Air Force
I heard Transgo is the good one. I am looking into one. How hard does it shift?
I have stock Stall, but I have the Line Pressures boosted by the Tune. It goes squirrelly from first to second already.
Old Oct 30, 2006 | 04:42 PM
LT1BRN's Avatar
transgo is what you're looking for, have it in m car, and eery one else i know with a 4L60E have it no problems at all.
Old Oct 30, 2006 | 05:07 PM
the_merv's Avatar
Veteran: Air Force
Wonder how it would do in mine. It feels like it has a kit already..
Old Oct 31, 2006 | 01:06 AM
onebadblackz's Avatar
mines was the same way merv but if I get up too 5500 and then go into 2nd the tires spin forever
Old Oct 31, 2006 | 01:23 AM
JUICED96Z
Guest
Posts: n/a
Is there a point in having one if you have a stall with the line pressure kicked up?
Old Oct 31, 2006 | 01:44 AM
with a stock stall it sucks...get a biger one it will shift realy firm and hard under normal driving and you proablably wont like it... in my opinion
Old Oct 31, 2006 | 06:10 AM
Internet Mechanic
Line pressure create heat and kills transmissions, its better then nothing but its really a hack way of doing things, real drivers use the shift-kit.
Old Oct 31, 2006 | 08:21 AM
Mrwilson's Avatar
or shift kit and multiple tranny coolers.
does the shift kit also help to increase the longevity of the tranny's life?
while on the idea of heat in your tranny. If you have a trans temp guage, where do you have it mounted?
Old Oct 31, 2006 | 09:15 AM
Internet Mechanic
You can put a temp guage in the A piller. I ran 1 B&M tranny cooler, the fluid is still fruit punch red. I ran it in conjunction with the stock radiator cooler. it is a new radiator.
its good to have adequte line pressure, this makes clutches not slip as much. A manual/mechanical shiftkit is the way to go.
Keeping temps down and a shift kit will make a tranny last longer in any application
