Time for a new Opti... which one?
Old Oct 31, 2006 | 09:25 PM
Daez's Avatar
Default Time for a new Opti... which one?
I seriously don't want to have to deal with this **** again. I will be camming the car evntually, so I'm gonna need to get a good one that will hopefully not break =\ Search is not working(opti search pulled up 4 links), so what are you suggestions? I'm running a 94, daily driver, will be doing head/cam/nitrous.
Old Nov 1, 2006 | 12:28 AM
mike2244's Avatar
msd opti
Old Nov 1, 2006 | 01:15 AM
kc-unit's Avatar
I would also say msd. They are proven...
Now IF you can afford it.. I would stray away from the standard OPTi all together.... Go with a delteq set up.. The Delteq uses 4 Northstar/Cadillac ignition coils.. there is also another set up.. I really dont know much about it.. just read about it is all but it is the LTCC which uses 8 LS1 ignition coils...
If you can't afford that route.. just go with the MSD distrubitor and cap and rotor... Make sure you replace both at the same time.. other wise you will find your self replacing them both when the one not replaced goes out.. so that just means more money and doing the same job twice...
hope that helps a little....
~KC
Old Nov 1, 2006 | 02:03 AM
JUICED96Z
Guest
Posts: n/a
Is the MSD worth it over the ACCEL considering you can get the ACCEL for $200 threw JC Whitney and northern auto parts
Old Nov 1, 2006 | 04:30 AM
Charging TA's Avatar
MSD opti is proven? I was seeing a bunch of a posts when it came out about how alot of them had already broken.
Old Nov 1, 2006 | 07:41 AM
ToxicFormula's Avatar
I love my Dyna Spark, havnt had one problem since I got it
Old Nov 1, 2006 | 07:46 AM
Silver LS1's Avatar
Delteq is THE only way to go.....
Old Nov 1, 2006 | 12:22 PM
Bawls's Avatar
Exactly what I was thinking. I personally went with a stock replacement. None of the aftermarket companies really have had time to prove theirs is any better. Not to mention mine lasted 154k. So I know it works.
Old Nov 1, 2006 | 12:48 PM
I don't know if its officially "proven" but the DynaSpark is deifnelty built to last cause mine survived being in a car when it was totalled and is now on my 94 formula and is still runnin stronger than ever. just my 2 cents
Old Nov 2, 2006 | 12:31 PM
Daez's Avatar
Why does it seem like the first opti will last 100-150k miles, then everytime you replace it it dies in 20k?
Old Nov 2, 2006 | 01:05 PM
Y2K Pewter SS's Avatar
i'd go back with the delco. Most go out after 100K and for a factory part that is used so much.....thats bang for the buck. Ed wright still trusts the the delco on his 500rwhp 10 second N/A T/A.
Old Nov 2, 2006 | 11:01 PM
Daez's Avatar
I imagin on a 10 second N/A he revs pretty high, I thought the stock/delco opti had problems over like 6200?
Old Nov 3, 2006 | 08:30 AM
lifeisgood's Avatar
i have the msd and have had nothing but problems. im gonna go back factory
