Victor Jr setup w/conventional distributor pics
We just finished up on Phatkops setup...Single DRY setup (200HP) run threw a Victor E and a MSD crab cap dist. controlled by FAST....
Car now goes to 7200 without a hitch....
Here's the pics....https://ls1tech.com/forums/eastern-members/603356-94-lt1-383-stroker-pictures.html
man, you read my mind when it came to this setup (minus the plate system), although I've started mine with a standard victor jr (carb style). and we laid the injector angle back as far as the mill would go without the spindle hitting the carb mounting surface (ok, so it's only like... 8* back, but still)
is that an edelbrock TB on there?
exactly how much room is between the top of the TB, and the wiper cowl?
does the distributor slide in with the intake bolted down, or do you have to slide both in at the same time, and fight with it for half an hour?
awesome looking setup, will have similar one soon!
Originally Posted by JS
Yes its an edelbrock TB
There's only 2in of room at the top of the cowl,we're maing a custom air cleaner for it
U must drop the intake and dist in at one time.....
that's kinda what I figured when I mocked mine up one day (no TB yet) if you don't mind me asking, what are you going to try for the air cleaner?
