Audio/Vid of my 383 Combo
Old Nov 7, 2006 | 07:49 PM
gixxer92's Avatar
Default Audio/Vid of my 383 Combo
http://www.youtube.com/watch?v=TcB-Jc3RSdA
BTW, I'm trying to teach the 13 year old how to goose the throttle.... and the 10 year old gave you the close up of the tail light
Lights off is about a 100 degree water temp and lights on was 160 warmed up, Dan at FLP tuned the car in August of this year with the 4L60E in it.
Specs
K&N cold air intake
Holley 58mm TB
36lb Racetronix Injectors
Holley 255 Racetronix wire harness
Fuel pressure set @ 45psi
Ported intake and heads by CFM Performance out of Indianapolis
2.08 / 1.60 valves 58CC chambers 1.6 GM Rockers Comp hardened pushrods
Comp Cams XFI 268 IVC ABDC 63 degrees w, 918 beehives
4.030 bore 0 deck, Eagle Rotating assembly SRP -5CC pistons
ARP bolts throughout
Canton Road Race Oil Pan 242-T
1/4 fill of Blok hardner
MSD 8.8's, coil, and 6AL, stock plugs (indexed)
FLP headers, Borla Exhaust w/ elec cutout
Fresh M6, new Mosier 12 bolt w/ 3:42 gears
Old Nov 7, 2006 | 07:53 PM
White 96LT1's Avatar
don't work?
Old Nov 7, 2006 | 07:58 PM
gixxer92's Avatar
It's acting funny sometimes it does, sometimes it doesn't, is this normal with youtube? I've never used it before?
Try it again I hit it and it went right to it
Old Nov 7, 2006 | 08:05 PM
It works. Sound just like my car. identical!
Old Nov 7, 2006 | 08:19 PM
gixxer92's Avatar
Kinda stock I think
Old Nov 7, 2006 | 08:41 PM
knowitman's Avatar
Sounds nice.
Old Nov 7, 2006 | 08:57 PM
gixxer92's Avatar
Just to complete the mods list.
Poly Urathane bushings all the way around front/rear, motor mounts, trans mount
BMR Sub frame connectors
BMR Strut tower Brace
New Moog ball joints
Bilstien matched springs & shocks
C5 Front brake upgrade 13" Rotors (AC Delco rotors, cross drilled)
Spohn rear sway bar
Spohn Lower control arms
1350 Yokes on alumium drive shaft
Z06 rims 17x9, 19x10.5 Michelin Pilot sports
Edit - the BAD
T-TOPS! (I hate the rattles and leaks)
MEAN LT1's Avatar
Nice setup, gotta love a Borla.
