4.10 ???s
Old Nov 10, 2006 | 01:11 PM
chameleongreen97ta's Avatar
Default 4.10 ???s
when you are driving on the highway and cruising at 70 what are your rpms i always go 70 and i am thinking about putting 4.10s in my car
Old Nov 10, 2006 | 07:02 PM
Revelation Z28's Avatar
im at 2000rpm in 6th.
Old Nov 10, 2006 | 07:12 PM
ZFan88's Avatar
I'm a around 1800 at 70...somewhere around there
Old Nov 10, 2006 | 07:25 PM
Mens Rea's Avatar
In my stock '95 Elty with an M6 and 4.10s, I turn 1850 @60 and around 2100 @70. But since the gears, I haven't gotten any less than 20mpg (worst of 20.16, best of 27.7) and I drive half city, half highway.
Old Nov 10, 2006 | 10:20 PM
i get like 24mpg freeway since i seafoamed the car twice.
i dont really like my 4.10's though. you cant spin the tires long enough in 1st and 2nd without banging the rev limiter or having to shift.
i like the fact of spinning 3rd though.
and also the fact that you loose maximum mph in each gear compared to 3.42, and top speed. i cant do 170 anymore.
Old Nov 10, 2006 | 11:33 PM
coldkillinTA's Avatar
i have an A4 and i turn about 2600 @ 70 but i still get around 310-320 miles a tank..
Old Nov 11, 2006 | 12:35 AM
ZFan88's Avatar
lol, i can spin all day long, it's called throttle control. get some drag radials and don't even spin into 2nd at all, simple solution. No point in doing 170 unless you're trapping that
Old Nov 11, 2006 | 01:38 AM
there is no throttle control with me lol
1/4 throttle i spin 1st, 1/2 throttle i spin 2nd and a little of 3rd.
Old Nov 11, 2006 | 02:05 AM
Speed Density's Avatar
hashtagBMW
Non-Lockup Trans-3200 Stall-4.10s=3500 to 4000 on the Highway.
210 to a tank.
Tony.
Old Nov 11, 2006 | 03:46 AM
dam. thats a high rpm to cruise at.
210 to a tank. thats almost enough to get to vegas from here.
210 to a tank.
Tony.
Old Nov 11, 2006 | 11:31 AM
camar0corey's Avatar
170? How is your bolt on car going that fast?
In anycase I used that gear calculator somewhere, with 4.10s you should be able to hit 150mph. Thats only 5mph slower than it did factory. I'll gladly trade that to get rid of that slow *** acceleration in 1st.
Old Nov 11, 2006 | 10:32 PM
JUICED96Z
Guest
Posts: n/a
Bet it had 2.73's and had a good wind to his back and or going down hill lol
Old Nov 11, 2006 | 10:48 PM
93 blackformy's Avatar
170 ...thats pretty fast...just curious, how do ya know ya going 170
can't wait ta get my 12 bolt and 3.73's...I'm into drag racing not nascar
Old Nov 11, 2006 | 10:52 PM
well with the speed limiter removed on most LT1's and LS1's with 3.42's you can hit 160mph.
back in my 3.42 days i was at 140 or so and it still wanted to go.
Old Nov 13, 2006 | 08:30 AM
LoStOCeAnZ63's Avatar
Talking
i needle goes past 150...150 in 5th gear and then i shift to 6th and it drops back down to 4,000 rpms s im sure the car can do 170 pretty easy i get up to 150 easy as it is and i dont even have much performance stuff done to my car really
Old Nov 13, 2006 | 09:17 AM
moserman's Avatar
they make 200 mph speedo conversions ive seen, that would be a good idea for you guys who dare to get up past 150, last time i tried hittin 150 i snapped my driveshaft and DESTROYED my pinion yolk, go figure!
Old Nov 13, 2006 | 09:33 AM
I have almost every bolton in the book, and I had lots of room out in CA to go faster, once 5th is done with the 3.42s the car basically dosen't want to accelerate much anymore, I've tried on multiple occations.
With bolt ons and stock 3.42s in a M6 car you are not going to go 15mph faster than the factory rating. You shift into 6th and it wonders what the hell?
Not trying to be a pain in the ***, but you mention you only took it to 140 anyway, so I guess we will never know, maybe you have the miracle car or something.
I had the same issue with my 86 Camaro back in the day, shift it to 5th, hope you have 20 miles of space to try to move that needle, cause its not going to go anywhere.
I know our cars have no problem really pulling 5th, but come on 6th is double overdrive, not even the new badass z06 vette pulls 6th, so lets all be realistic here. If a way lighter car with 200 more hp than we have can't do it, we sure as hell aren't going to.
Old Nov 13, 2006 | 11:57 AM
well the 4.10's wind out 5th at what 145? or something.
ill try it on the dyno lol ill hit 6th then hit a 150 shot.
Old Nov 13, 2006 | 01:53 PM
Ironxcross's Avatar
lol, these cars are way too much fun
Old Nov 14, 2006 | 09:31 AM
Using that gear calculator that is out there, with a M6 and 4.10s 5th should wind out at 150mph, only 5mph slower than with the 3.42s. I'm hoping that with the 4.10s maybe you can slowly accelerate in 6th, cause with the 3.42s I swear the car dosen't pull at all, the needle is just chilling between 3-4k.
If I've heard right you shouldn't hit your car with spray in 6th, dosen't that put alot of stress on the motor?
