Need alittle valvetrain help?
#1 I need a set of lifter to handle the LE3 cam. I kno the Morel lifters are better than the comp cams lifters but how much better? What are the pros and cons of the two?
#2 The heads will have beehive springs on them I wanted to kno if self aligning rockers would work with them or not, or is it better just to switch to nsa rockers and guide plates.
Any info is appreciated.
If I were doing an LE1 for an engine that almost never saw over 6000, with a lot less cam than a LE3, I might look at the 1318s. Looking at one now, I see where there might be some interference of the SA tabs with the spring retainers. I'd find that in the build up.
Why are you going LE3 and not LE2, BTW? Do you have all the supporting stuff to make the 3 work?
My $.02
Lloyd OUGHT to have the answers to this.
Listen to OldSStroker he is getting the info straight from the horses mouth about the valvetrain ;-)
LE3 stuff needs a built 355 bottom end at the least, 383 would be even better.
Bret
or woul0d you be better keeping a stock bore with a 3.75 crank and have room to keep going without having to buy new crank?
There's never a free lunch when you double the stock hp.
