ls1 torque vs lt1 torque
Old Jul 22, 2007 | 01:08 AM
  #121
94CamaroZ28SS's Avatar
i put down 335 RWTQ with a slipping tranny which is now rebuilt.
Old Jul 22, 2007 | 09:25 AM
  #122
LS1W66's Avatar
Originally Posted by Bonesaw85
That's absolutely true, in a race, the LS1 will give the LT1 a beatdown, I'm not debating that, that's common knowledge to anyone with half a brain.
But, for low rpm, um, "grunt", restriction actually seems to be the order of the day. The early 4.6L mustangs took a dirtnap at about 5k, but, until about 4K, they'll out-power a later 2valve. And, if you've ever looked at the low and mid-lift numbers of unported Non-pi cylinder heads, whoa boy, they're pretty pathetic.
They were a truck motor in every sense of the word.
The restriction you speak of isn't really a restriction it's just how the engine keeps good velocity at lower rpm's which is the normal operating range. At higher rev's though it obviously becomes a restriction to building good HP.
Old Jul 22, 2007 | 12:30 PM
  #123
Grn4fbody's Avatar
Originally Posted by Formula350
But who dyno's their stock setup car? :\
I did, with a bad opti
Old Jul 23, 2007 | 07:22 PM
  #124
FAD2BLK93's Avatar
Why does it have to be about a driver that doesn't know how to drive...face the GRIM F'N facts LS1's can't keep up with an LT1 on the bottom end...PERIOD! Now swallow that and move along.
Old Jul 23, 2007 | 08:31 PM
  #125
MadMike 97 Z28's Avatar
AMEN!!!!!!!! we all know LS1's are better engines overall than LT1's which is why they made LS1's instead of keeping LT1's. that being said LT1's MAKE MORE TORQUE AT A LOW RPMS BUT AT HIGH RPMS THE LS1 IS BETTER!!!! IF YOU GET HONEST OPINIONS FROM CURRENT LS1 OWNERS THAT HAD LT1 CARS THEY WILL TELL YOU THAT THE LT1 FELT STRONGER AT LOW END BUT THE LS1 WILL TEAR UP A LT1 ON THE TOP END!!!!!
END OF STORY!!!!
