price to swap an engine out?
Old Nov 23, 2006 | 12:43 AM
white93z28's Avatar
Default price to swap an engine out?
say i have a 93 Z with a knocking engine... say i find a good low miles 93 or 94 LT1 to swap... what should i expect to pay to have a good shop do it and do it right?
Old Nov 23, 2006 | 12:48 AM
GOaT Cheese's Avatar
I charge between 21 and 25 hours, at $100 an hour.
Old Nov 23, 2006 | 12:50 AM
white93z28's Avatar
fugg that... i'd probebly do it myself if thats average price..
Old Nov 23, 2006 | 12:54 AM
LOL... remember, they come out the bottom. I have seen it done through the hood opening, but I think that way is actually more difficult, you have to pull the engine down to a short block for that to work.
Old Nov 23, 2006 | 01:00 AM
white93z28's Avatar
how about installation only? whats average cost? i can pull an engine no problems.. hell even bolting it back into place isnt the problem... all the small details, wires, ect ect.. bother the hell outta me.. i'm used to 4 wires, distributor,alternater,and starter, and an electric choke on a carb...
Old Nov 23, 2006 | 08:33 AM
Out1aw's Avatar
just unplug stuff, take lots of good pictures while you do it and label it. It's not really that bad.
Old Nov 23, 2006 | 08:55 AM
aboatguy's Avatar
For about 50 bucks you can buy the happy hooker from TPIS, it's designed so that you can remove an Fbody long block from the top.
Check out this link where a cat is removing a long block from an F-body with the happy hooker.
http://www.akmcables.com/l99.htm
I bought one for my vette so that I don't have to remove the intake the next time I pull the engine.
The wiring on the LT1s is pretty simple, just take some pictures and label everything.
MIke
Old Nov 23, 2006 | 10:04 AM
MUSTANGBRKR02's Avatar
all you have to do is remove the a/c condensor and the radiator and it all comes out together!! i pulled out everything on mine thru the top and it was all installed water pump and everything. all you need is a cherry picker!
MIke
Old Nov 23, 2006 | 10:10 AM
the_merv's Avatar
Veteran: Air Force
Do it yourself, that way you can learn some stuff in the process. It's not that hard really. Did it in a couple of days.
Old Nov 23, 2006 | 10:15 AM
jd783's Avatar
happy hooker through the top removed rad abd ac condensor pullued the rest out together and installed with all acc and manifolds attached wasnt bad swapped it in 8-10 hours
Old Nov 23, 2006 | 11:07 AM
2fast97Z's Avatar
where ya live? ill do it for way cheaper than a shop will
Old Nov 23, 2006 | 12:08 PM
396D1SS's Avatar
it takes me around 12 hours to swap an lt1 engine out ofcourse using air tools
Old Nov 23, 2006 | 02:18 PM
Geneticallybroke's Avatar
I say do it your self...It's not hard just time consuming
After my 93'LT1 took a dump, I bought a 95'LT1w/88k for $550 plus brake fluid and antifreeze.
