Symtoms of optispark failure.
Old Nov 24, 2006 | 08:35 AM
ZEX-Z's Avatar
Default Symtoms of optispark failure.
Lets hear it. Any ideas.
Old Nov 24, 2006 | 08:43 AM
slow trap's Avatar
when they start going bad you will develop a miss.i usually notice it when i go up a hill or something in high gear at a low rpm and when i try to acelerate it misses.my distributor is out as we speak and hopefully today i'll get it put back together.
Old Nov 24, 2006 | 09:26 AM
ZEX-Z's Avatar
What are all the components that work directly with the optispark ignition. Besides wires ang plugs.
Old Nov 24, 2006 | 10:43 AM
streetwarrior96's Avatar
hard starts, takes a couple of turns for the motor to turn on
Old Nov 24, 2006 | 11:44 AM
ZEX-Z's Avatar
thank you.
Old Nov 25, 2006 | 02:16 PM
DCStroker347's Avatar
ya agreed with tehm
Old Nov 26, 2006 | 01:08 PM
slow trap's Avatar
if you haven't put wires and plugs in yours yet be prepared for a frustrating time on the passenger side,it is a bitch !
Old Nov 26, 2006 | 01:43 PM
ZEX-Z's Avatar
Been there done that, mastered that.
Old Nov 26, 2006 | 02:29 PM
vanilla89's Avatar
lloyd put 3 opti's, 4 set's of plugs, and 3 set's of wires on his befor it would run right now it runs 11.55 @117 all day.what wires do you have??the only ones that worked wright on llotds car where some cheep ones from oreally's,the msd wires would start to miss at high rpm,and if it does that the plugs will go bad .so if it's not running right im shure the plugs are dead plus whatever els is wrong.lt1 are a PITA
good luck
