rocker adjustment
Pastvertical,
Just remember, you CANNOT adjust aftermarket rockers the same as you would the stockers. Less preload also allows higher and faster revs, from what I understand. Also, one full turn on a 7/16" stud is not the same as a full turn on a 3/8" stud.
Originally Posted by buffman
still whether you're using a 7/16" stud or a 3/8" stud all stock lifters are the same and that is what dictates preload.
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Originally Posted by seawolf06
One full turn on a 7/16" stud will put MORE preload on the lifter, no matter what lifter it is. That's all I'm saying, it may not be enough to make a difference on most rockers, but that's why a range is given.
Gotcha
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
thanks for all you input i think im going to adjust them using the hotlash method. but should i get them to zero before i start the motor? and isnt oil going to go everywhere?
just start the car up and go from there.
