Those with a Moroso vaccum pump...come inside
#61
ohh ok... i must have read it wrong.. i thought you said you tried but couldnt get it to work... it funny after reading this whole thread i got my new issue of High Performance Pontiac and they have a whole article on installing a Moroso Vacuum Pump on big cam and displacement motors... havent had the chance to read it yet but should be very informational...
#63
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
excellent post, thanks Tony and all who have posted. I am running the Mr gasket pump, and a simple brass regulator. I adjust it when i am at the track
cog belt is a plus, no slippage!
i also have the LT1 head specific moroso fabricated covers, not cheap but rather nice!
great info!
great info!
#65
Originally Posted by Ed Wright
Looks like your vacuum pump hose is in the top of the valve cover? Looks wrong to me, especially if you think about the amount of oil the rockers put up there. They told me to use the front ends of the covers, or upper side, behind the pushrods. If you don't have very low tension rings (lower than what comes in the box as "low tension") the gains will not be real big. I see a constant 10 rwhp change from taking the belt on & off. That is just the belt, not including the ring pkg. Smokes a tad with the belt off, and with it on lately since the cylinder walls are pushed out of shape and the rings worn out. These blocks move around a lot when you lean on them. Not real stong.
#66
Originally Posted by roadtrip120
I was looking at these Star Machine pumps for my 383 buid, anyone use these and have good luck?? I know INTMD8 uses them.
No regulator needed, 12 to 15in vacume, and nearly the same CFM as the standard pump you list above until 6000rpms or so... even then it's comparible. And it's cheeper.
#67
http://go.mrgasket.com/pdf/P1820.pdf
above is the unit i went with recommendations from Brian Harshaw, my builder.
#68
Originally Posted by Tony Shepherd
Thank you for your help!!!!!!!!!! I just ordered what I needed.
Bret
When I get some time I will get you part#'s on what you need.
This is how we mounted mine.
Bret
tony care to tell about the bracket thats mounted to your heads the plain alum one i got the blue one made for a motor plate
hey ed funny how i just called askin about mounting of the pump and i just found this thread
#69
#71
This is a great thread..... I'll be gettin ready to order my complete setup real soon since i'll actually have a motor to bolt it to.... I'm thinkin I like the Reher morrison setup.... steep at 799 but if it includes everything I need to avoid problems I might have to pick it up...
As an aside my custom fabbed valve covers have the pickup fitting welded in the front near the top so I might be able to avoid the problems you've been having Tony.... my engine builder puts all his fittings in that place....
#72
Tony,
Off topic, but which MSD Distributor did you go with? The P/N 2345 or P/N 2340? Or since you are running B2B like I am did you just have to use a standard crab tree P/N 8486?
Thanks,
Dave
Thanks,
Dave
#73
With the Reher & Morrison kit I had only to buy one bolt to install it.
#74
Originally Posted by Dave95Formula
Tony,
Thanks,
Dave
Thanks,
Dave
