What is this?
First picture is the thing(looks like a small electric motor)
Second picture is where it is located on the engine.
-Brandon
Do you have a button on your center console for that. If so, can you take a picture for me and post it. According to my RPO numbers, my car is supposed to have traction control but I don't have that box, and there was a small hole in my center console that I thought may have been where the switch was. Anyway, I am sure you can delete it as mine clearly has been. It will leave a hole in the console if you remove the switch i guess. You can do what I did and fill the hole with filler and paint the console.
I don't know if i gave any info you were looking for. If not, sorry, I am just rambling on today.
-Thanks Brandon
-Brandon
here is a pic for ya the trac button is right next to the perfrom button sorry cant read it in the sun.
Oh and yes the cruise is linked in with the TC so is the ABS to remove it you need the trac/ABS delete kit SJM sells them for about $199 i think. other then that no help this helps.
-Brandon
Thanks for the picture, yeah that whole grey assembly that the switch is on is gone in my car. There was just a small hole under it where I assume the wires went.
When I start my car, the "traction" light lights up for about 1 second with all the other lights, and then goes off. So I don't know whether it is on or off, I assume off since I don't have that box in the engine bay.
I will have to see if a TCS light comes on the next time I start my car, I don't think I have ever noticed it.
