lt1 clearanced oil pan
Old Dec 18, 2006 | 10:38 PM
2fast97Z's Avatar
Default lt1 clearanced oil pan
what pans are available to use on 383's? please send links or just somethin i need to order one tonight...the moroso one that shows on summit isnt stroker clearanced
Old Dec 19, 2006 | 05:42 AM
MUSTANGBRKR02's Avatar
Do it yourself! I'm going to do it tonight as a matter of fact.
Old Dec 19, 2006 | 06:28 AM
CatchinZs's Avatar
Clearancing it yourself isn't that hard. Just make sure you take into account the rod as it moves by the pan. I didn't "adjust" my pan enough and I had to pull the pan to make a few minor adjustments so the rod would stop brushing against the pan.
Old Dec 19, 2006 | 07:15 AM
Camaroholic's Avatar
If you're considering using the stock pan, I think the amount of clearancing is also going to depend on your rod selection as well. My Lunati rods didn't require much clearancing on the pan.
Pictures here:
http://www.caspeed.com/gallery8/index2.html
Show clearancing for Eagle rods. Mine didn't require nearly that much.
Old Dec 19, 2006 | 09:29 AM
sleeperMULLET's Avatar
the canton pan doesn't need to be clearanced
Old Dec 19, 2006 | 12:57 PM
CatchinZs's Avatar
I used the eagle h beams and I didn't really need to do much at the pan rail.
My contact point was about a 1/2 to 3/4 inch down.
Old Dec 19, 2006 | 01:06 PM
streetwarrior96's Avatar
Using the Canton 7qt on mine... no probs
Old Dec 19, 2006 | 01:20 PM
-PEPE-'s Avatar
Canton pan actually does require a little depending on the rods used, my Callies H-beams just touched the inside screen/baffle and they just had to be pushed down an 1/8" or so along the edge, otherwise they cleared fine.
Old Dec 19, 2006 | 01:25 PM
yeah, i quess your right, it does depend on which rods you use, in my case i didn't have to clearance the pan.
Old Dec 19, 2006 | 01:50 PM
2fast97Z's Avatar
ok well i have Scats i -beams w/ arp rod bolts and i already clearanced my stock oil pan and didnt do it enough and it put holes in the damn thing so i just want to buy a damn one thats already done
