Kinda need some direction...
For those of you whom have a more completed projects, where would you start if your ultimate goal was to have in the neighborhood of 400-425hp? What would you have done differently?
I'm no expert but, I wish I had the money for a low-medium boost supercharger setup and that would probably put me at or close to the 400RWHP mark I think.
I have not dynoed my car yet, but on spray I should be around 420-430 rwhp. Last time I was running at the track I managed a 12.06 @ 117 with a 1.8 60'.
It all depends on the duties of your car. You can set up a nasty heads/cam package from a reputable porter and make close to 400 on motor alone, but you're going to sacrifice some daily driveability.
That said by most opinions my car has to be somewhere near the 400rwhp mark and is daily driver friendly, in spring I even had 3.42s in it yet, and went 12.6 first night out on a rich mailorder tune.
In a lighter f-body you could certainly tolerate more cam.
A budget 355 could help wring out a little more power as well.
To do things "cheap" you need to do them just once and get it right, I am on my 4th torque converter, third set of rockers, second set of tires(first not worn out just wrong tires) etc. the list goes on.
Thats a good point about the performance goals. I know I want to keep up to both my friends LT1s whom run in the low-mid 12's. I don't know if thats easy or can be done on a very limited budget. My 94 has had already some mild port work and has about 11:1 compression, the head gaskit blew when it was still my buddies car. The Opti is throughly trashed due to moisture and in need of exhaust work. I was thinking of starting with a new opti or deltec and headers with dual or single cutouts(Havent made my mind up) with the stock cat-back, then going from there
You could make 400rwhp on a budget easy. (Depends on teh budget
)Tony.
The problem is we all get "use" to the power and we want more and get this fixation in our minds that we have to have more so we end up going crazy with these builds and we either 1)never finish them or 2) end up spending to much money and complicate our setups to the point where we don't feel comfortable driving them everyday. Then you end up with a beater to drive and you park fun car only to drive it every once in a while and never enjoy it like you did before you went crazy with it.
Maybe this is just my story....
